ABS light
Old Nov 25, 2004 | 10:06 PM
ckstrawser's Avatar
ckstrawser
ABS light
2000 Ford Exp. 4x4 AWD, 70,000 miles. The ABS light just came on. Checked the brake pads (checked Good) Brake fluid also (checked Good level). Both Advance & Auto Zone said they do not read ABS light/codes. So how do I figure out the code/problem? Any help much appreciated.
Old Nov 26, 2004 | 08:57 AM
waro's Avatar
waro
Coul be a faulty speed sensor located on top of rear differential.
Old Nov 26, 2004 | 09:12 PM
waro's Avatar
waro
Hey ckstrawser Following is what I tried to say, sorry for my english as it is my second lenguage, I live in Venezuela South America
" Most likely cause for abs light on is the wheel speed sensor that sits on the top of the reaend housing. I have replaced many of those in my repair shop. Easy to replace."
Old Nov 29, 2004 | 05:53 PM
ckstrawser's Avatar
ckstrawser
Abs
Do you guys have a break down of exactly where this sensor is? And how easy is "easy to replace". I don't have to drain the Diff or anything do I? Thanks for your reply. Also any idea how much the part costs?
Old Nov 30, 2004 | 11:05 AM
shaggymane's Avatar
shaggymane
ckstrawser,
they aren't bad to get to. look for wires coming down to the top of the *jug area* where the ring gear and pinion are.
IIRR, it's something like a 7/16th's bolt that holds a clamp, then pry the sensor out. You'd want to clean any dirt away from the whole before pulling sensor.
Try wiping the sensor off and reinstalling it, see if the light goes out. If it does then change the fluid.
Ps. my sensor didn't look dirty but I wiped it anyway. Light went out.
Old Nov 30, 2004 | 01:32 PM
bigmikeok's Avatar
bigmikeok
I just had the same problem. It is easy to fix. The sensor is on the top of the differential towards the front of the truck. It is the only electrical connection coming out of the differential.
The part for mine cost about 25 dollars. The whole thing took about 30 minutes including clean up.
The light is an automatic reset. There is no code to clear.
For the cost and the ease I would just replace it.
Old Nov 30, 2004 | 06:12 PM
ckstrawser's Avatar
ckstrawser
Thanks
Thanks guys, but still question is do I have to change or drain off any diff fluid in order to change the speed sensor? Vehicle only has 70K on it so if it is not required I don't really want to have to change it.
Old Nov 30, 2004 | 07:47 PM
shaggymane's Avatar
shaggymane
in a word,no.
Old Dec 2, 2004 | 01:06 PM
slenser's Avatar
slenser
Hi guys. I'm new here and new to ABS repair. I just tried replacing my rear speed sensor (super easy) and I still got the ABS light on. Any ideas where to turn to next? Mine would come on intermittently(sp?) and then finally went on solid. This is on a 94 Explorer.
Thanks,
Sam
Old Dec 2, 2004 | 02:30 PM
93explorertom's Avatar
93explorertom
I have a 1993 explorer sport with the same problem. I think the locatioin of the sensor is up front, but I'm not sure. Can anyone point me to the correct location?
Old Dec 2, 2004 | 02:52 PM
slenser's Avatar
slenser
If you are talking about the rear speed sensor, it is on the rear axle housing, on top, somewhat towards the front of the housing. I just put the jack on the frame and lifted it up as high as I could. It took a 1/2" socket to get the bolt out. Took me all of 10 minutes.
It didn't fix my problem. I hope it does for you.
Good luck,
Sam
Old Dec 2, 2004 | 03:00 PM
93explorertom
Thanks slenser. I'll try it out.
Old Dec 2, 2004 | 06:00 PM
shaggymane's Avatar
shaggymane
gonna try somehting here. See if i can get the hyperlink to work.
It should go to a recent more in depth thread about RABS .
https://www.ford-trucks.com/forums/s...ighlight=rabs+
Old Dec 2, 2004 | 06:13 PM
shaggymane's Avatar
shaggymane
if you new guys want a head start before the guru's show up
right click search
left click on open in new window and it'll bring up the advance search page
type in your year and rabs in key words
then scroll down to
Search in Forum(s)
small chassis trucks
Highlight (click on) Explorer, mountainer etc
If this is telling you what you already know just trying to be helpless here
Old Dec 2, 2004 | 06:16 PM
shaggymane's Avatar
shaggymane
and it should bring up something like this.
https://www.ford-trucks.com/forums/s...earchid=410908
