ECT EOT
Old Apr 19, 2011 | 01:25 PM
i eat hybrids's Avatar
i eat hybrids
ECT EOT
I had a couple of questions about ECT and EOT differences.
I recently had my EGR/Oil cooler replaced along with VC-9 flush 10,000 miles ago. I was towing my trailer yesterday, which is 20ft dual axle that prob weighed in at 5k. So my question is, my ECT and EOT dont go over a 10 degree difference no matter how hard you work her which is good. But yesterday while i was towing it was prob 50 degrees out so it wasnt warm at all. The temps were climbing It was about 210 ECT and 218 EOT on my insight CTS. Now i know the difference is normal. But how hot can those temps comfortably get? Is that a normal temp to be seen towing 5k @ 50 degree outside temp? At what point temp wise (ECT, EOT) does a 6.0 defuel?
Old Apr 19, 2011 | 01:34 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I can't answer ALL your questions, but I can tell you your temps are fine! Were you stop and go or straight highway driving?
Old Apr 19, 2011 | 01:48 PM
i eat hybrids
It was straight highway. I need to find out at what temp EOT ECT wise that a 6.0 will defuel because you can set it as your max thresh on the Insight CTS.
Old Apr 19, 2011 | 02:11 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
You need bismics spread sheets.
https://www.ford-trucks.com/forums/9...-pressure.html
Old Apr 19, 2011 | 02:45 PM
i eat hybrids
Thanks for the link! Looks like my rigs on the boarder line Gotta start off with the code shes throwing.
Would 5k be severe service?
Old Apr 19, 2011 | 03:02 PM
amdriven2liv
By "Severe Service" I believe it means "putting my foot in it to get up the mountain as fast as I can get there pulling the 8,000# TT."
Normal I believe is empty, pulling nothing.
I've seen my EOT get to 230* climbing Sexton Grade on I-5 in southern Oregon in the summer. Wasn't there long, but it did get there.
Old Apr 19, 2011 | 03:29 PM
i eat hybrids
Ya i dont think pulling 5k, low profile trailer in 50 degrees would be considered servere usa. Looks like my cooling syst may have an issue.
Old Apr 19, 2011 | 03:57 PM
dchamberlain's Avatar
dchamberlain
The thermostat isn't even fully open until 219. I don't think 210 is anything serious.
Old Apr 19, 2011 | 04:39 PM
amdriven2liv
I am with the other 2 posters.
Your temps are fine. Or at least I wouldn't worry about it if I had them.
Old Apr 19, 2011 | 04:53 PM
2006lariat's Avatar
2006lariat
When I pull my TT (7800#) on some of the hills, or even on interstate with a headwind my eot/ect's will reach into the 230 range. I would say your fine.
Old Apr 19, 2011 | 06:01 PM
rocky1074's Avatar
rocky1074
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->Engine begins to defuel at 253 deg. oil temp!!!!
Old Apr 19, 2011 | 06:03 PM
i eat hybrids
Ok thanks guys! I still have to figure out why my rigs throwing a P0528 code which is a no cooling fan circuit. I may have a bad fan clutch on my hands. I'll let y'all know if my temps change or if my clutch is bad or not. Either way gotta wait till pay day till a can buy the clutch so it may take a while unforunatley
Old Apr 19, 2011 | 06:09 PM
i eat hybrids
Andriven once again thanks for the link. I printed out that post, cut it out and laminated it and put it on my fold down mirror lo or what ever you call it
Old Apr 19, 2011 | 06:12 PM
i eat hybrids
Do you happen to know when it defuels ECT wise?
2006lariat's Avatar
2006lariat
Is your EGR valve plugged in? If not it has some control over your fan.
I am not sure when defueling happens with ect! Never defueled on me. I know I got stuck in february, with the radiator blocked, it was getting pretty hot (in the 240* range) and it never missed a beat. (I unblocked the radiator and it cooled in a hurry)
