another death wobble question?
Old Apr 19, 2011 | 12:37 PM
cowgirlup11's Avatar
cowgirlup11
i just fixed my tie rod bushings, checked ball joints & tie rod ends. all are good. but just noticed my shock on my drive side is not tight..
i can twist it around but the other side is really tight & i cant twist at all. could this cause the death wobble?
also i took off my tires & cleaned out all the mud there was tons caked in there but still didnt fix the wobble it did make it a little better but i still have it. on my drive side roater the mud tore it up bad could a bad rotor also cause this wobble?
Old Apr 19, 2011 | 12:54 PM
montana_highboy's Avatar
montana_highboy
Define "death wobble" for us, that term gets thrown around quite a bit as a catch all phrase for all front-end troubles, in detail what exactly are you experiencing?
Justin's Green Truck's Avatar
If the rotor and shock are bad have them replaced. When is the wobble felt? During braking? Or crusing?
Old Apr 19, 2011 | 12:56 PM
justforkicks's Avatar
justforkicks
i think a bad rotor would only make for funny stops (like, lunge sort of stops) or you'd feel it in the brake pedal (would shuffle your foot around until the truck is stopped). all the death wobbles i've had were because of bad shocks, so yes, your shock may very well be shot. if the ball joints, tie rod ends, wheel bearings, and everything else is fine, then probably shocks.
Old Apr 19, 2011 | 01:06 PM
cowgirlup11
when i speed up to around 50mph now it starts shaking side to side but feels like its just the drive side tire doing this. before i took the mud out of inside my tire it could only get up to about 40 before getting wobbley.
wheres my track bar at?
Old Apr 19, 2011 | 01:08 PM
justforkicks
the track bar goes from the passenger's side of the axle to the driver's side of the frame. if it's a shake in the steering, it could either be a tire out of balance or like Justin's Green Truck said, a bad rotor. have the tires been balanced on your truck?
Old Apr 19, 2011 | 01:12 PM
cowgirlup11
no they havent been balanced since ive owned it. i heard my truck dont got a track bar cause its a f250?
Old Apr 19, 2011 | 01:16 PM
justforkicks
it may not have a track bar. i had one 77 f250 highboy in my life and my uncle turned around and sold it before i had a good look at it. clean the tires off so there's no mud and bring it to a tire shop. they'll balance all the tires for a pretty cheap price. i balance my own tires (using my buddy's tire balancer) and i never have any shaking problems anymore.
Old Apr 19, 2011 | 01:20 PM
cowgirlup11
thanks. im just going to replace the shocks and im getting a new rotor anyway ill do that too.
Old Apr 19, 2011 | 01:28 PM
justforkicks
alright. if that doesn't solve it then you may have a bent axle shaft or bad wheel or spindle bearings. it's always nice to have balanced tires though.
Old Apr 19, 2011 | 01:32 PM
bucks77ford's Avatar
bucks77ford
Another remote possibility is a bad tire. Sometimes a belt in a tire can break and go un-noticed until it actually shows up that you can see or blows out. The other time they are noticed is when vehicles start to drive terrible and are taken in to get balanced. Or it's possible a wheel is bent.
Old Apr 19, 2011 | 04:29 PM
edwin76's Avatar
edwin76
i agree, it sounds like a tire concern, or wheel concern, brake rotors only cause a vibration or shimmy if u will when they are worped, u can feel it when you are breaking. get the tires checked and balanced if possible. just my 2 cents =)
Old Apr 19, 2011 | 05:13 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Last time I checked a F250 (leaf spring front end) does not have a track bar, that's a
F150 (coils and radius arms) item only. But I have been wrong before....
Yes it could be a shock, but sounds like a warped front rotor since you have no wheel bearing noise right? The brake pedal will pulse when braking when they are warped.
Since you just had a jack near the front end, I hope you quick checked the front wheel bearings? With no load on the tire grab top and bottom and ck for play or use a 4 way at the bottom.
But probably a separated cord in the tire, get the hubby to swap front and rear tires and test drive it again. Good call edwin and buck...
And ck the steering shaft u-joint, the one between the firewall connection and steering box. At least you know its not the tie rods, even ck the "maybe" frame crack?
Old Apr 19, 2011 | 10:21 PM
skidoodave's Avatar
skidoodave
Have you checked your steering stabalizer shock? Do you even have one on the truck? If that shock is worn out and not providing any dampening then the truck will shake, sometimes violently if the front end or tires are'nt in good shape. Some trucks run 2 satabalizers just to keep the front end under control. My first 78 F150 with 38" mudders would litterly hop from side to side when the stabalizer shocks were disconnected, I had to run 2 of them to keep it under control.
Old Apr 22, 2011 | 10:15 PM
4bysnduallies's Avatar
4bysnduallies
put a steering stabilizer on it.it is a shock mounted horizontally on the drag link.
