Headers and carb connections?
Old Apr 18, 2011 | 08:09 PM
sfeverall's Avatar
sfeverall
I have a 76 F250 Highboy w/ the 360. It has an Autolite 2bbl carb. This weekend I swapped the original exhaust manifolds for a set of Hedman Headers. There was one tube from the original manifolds to the carb for the choke so I put on a manual choke to eliminate this problem. There was an adapter for the stock air cleaner assembly, I eliminated the air cleaner with a K&N setup.
My question lies with the remaining tube that was on the manifolds. It was right next to the choke tube and ran to the bottom of the carb. Can I just cap it off? Whats it for? truck seems to run fine with out it.
Thanks.
Old Apr 19, 2011 | 05:21 AM
strokerfe's Avatar
strokerfe
sounds like the tube that when you start your engine when cold engages your choke and as the manifolds warm opens the choke. If thats the case your fine without. Im sure someone else will chime in if not.
Old Apr 19, 2011 | 08:05 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I would plug it and see how it runs.
It should be plain engine vacuum (I think) that runs from the carb to the choke, and then to the exhaust manifold. As the manifold heats up, the air going into the choke warms up the choke which turns it off.
The problem is, I don't remember if that vacuum is on all the time (I think it is, otherwise the choke would eventually turn back on as it cools off). If that vacuum is on all the time, it's an "expected" vacuum leak like the PCV.
If you plug it, the carb will run just a slight bit richer. Your idle might drop a little bit too. I don't think it's enough to give a darn about though, so try it.
Old Apr 19, 2011 | 09:28 AM
sfeverall's Avatar
sfeverall
im gonna plat around with it and see. That may be perfect because as soon as i took the line off it idling a bit to quick.
sfeverall
Apr 18, 2011 09:20 PM
LARIAT 85
Mar 18, 2009 04:58 PM
DAdams
Dec 22, 2004 12:20 AM
don_79f250
Sep 27, 2004 04:07 PM
76 F250 4X4
Sep 20, 2004 12:12 AM
