Sponsored by: Auxito
Towing power
Old Apr 18, 2011 | 07:37 PM
tgraf88's Avatar
tgraf88
Towing power
New to the forum. I would like to know if anyone has added cam/ headers / electronic custom engine tuner to their 5.4 2V to increase towing performance and with what results.
I recently purchased a low profile 7x14 enclosed bike hauler and feel like I'm pushing the truck harder than I want. Approx. 5000 lbs. My truck is a 2000 4WD ext cab with 33x11.50's. I know the oversize tires don't help, considering added weight and dropped engine RPM.
Any recommendations??
Old Apr 18, 2011 | 09:23 PM
jgeese's Avatar
jgeese
Welcome to the forum!
Running the taller tires effectively changes the gear ratio. Taking your gear ratio and tire size the net gear ratio can be found, just don't remember where it's located. However, there are two choices! Change the tires or change the gear ratio. Adding more power to what your running will simply increase the load right down the drive train causing possible failure of parts due to a high effective gear ratio.
Something to think about, as I am dealing with a similar problem...
helifixer
Oct 8, 2009 07:13 PM
vtec
Escape & Escape Hybrid
May 13, 2009 10:29 PM
303soul
Computer Chips & Tuners
17
May 27, 2007 08:32 AM
sigtauenus
Sep 12, 2005 02:18 PM
ford390gashog
Oct 21, 2004 07:26 AM
