Hi Guys Need help, new to forum, first post. changing my glow plugs and got my 10mm socket stuck on last rocker arm on drivers side. any ideas?
1996 F350 PSD
Push it back down, screw the GP back in a couple threads, and remove the socket. Now, turn the loose glow plug with the socet held at a slight angle to the GP, this will let the socket come off when the GP is totally out, without sticking to the Glow plug.
Let me know if that works for you! Good luck!
Edit: what he said^^^^
Reason: too late
Anyway it worked great to grab the GP end and twist it the last few threads off that you can't do with the socket. You can get them about anywhere for a couple bucks.
Yeah, last set I did had oil all over them, they were a beotch to get out.
When I did mine on my truck, I wiped em all down, and stuck the hose on my cordless impact. I just broke them loose with the socket and stuck the hose on there and zipped them out.
