BCM failure - temperature induced - solved
Old Apr 17, 2011 | 12:58 PM
rdenis's Avatar
rdenis
So a couple of weeks ago my truck started exhibiting really odd behaviour. In the mornings after a cold soak, my "Service Advancetrac" warning message would come on and I would lose all steering wheel located controls and my exterior lights would all turn on and stay on, seemingly by themselves. Even when I turned the truck off the lights would stay on until the battery saver cut-off kicked in after about 15 minutes.
This behaviour would remain until I'd been driving for 15 or 20 minutes and then all of a sudden everything would correct itself and return to normal operations. But once the truck had sat for a few hours, I'd get the same issue recur.
In addition, a few times during the night, my truck would suddenly turn on all its lights, again remaining on until the battery save timer did its job and shut them off.
I monitored this behaviour for about a week and clearly it was temperature related - what I couldn't tell was whether it was operating temperature related or ambient air temp related. Each time it happened, the BCM started throwing "network communication lost" DTC's - mainly with the Steering Column Control Module (SCCM). I suspected the BCM was the culprit - probably a bad solder joint on the board that would expand and contract with the ambient temperature changes. Outside temps would range from -1 C (nighttime) to +10 C (daytime) during this period.
Anyway, long story short, Ford agreed and replaced the BCM a few days a go. Problem solved.
Old Apr 17, 2011 | 01:05 PM
kper05's Avatar
kper05
That's an interesting one.
Good thing it was a fairly easy fix.
Old Apr 17, 2011 | 06:06 PM
lexustbs's Avatar
lexustbs
Sounds close to what was happening to my truck. We dont want to go down that memory lane again though...
Old Apr 17, 2011 | 08:06 PM
rdenis's Avatar
rdenis
Yep I remember all too well...
mnero
6.7L Power Stroke Diesel
46
Dec 7, 2017 09:01 PM
TerraTug
Sep 4, 2017 09:53 PM
99FORD EXPY.
19
Mar 19, 2017 05:08 AM
Moon's 01f250
Modular V8 (4.6L, 5.4L)
Mar 30, 2016 08:08 PM
jtm1989
Jan 28, 2016 11:46 AM
