83 won't idle
Old Apr 17, 2011 | 11:45 AM
rschem's Avatar
rschem
83 won't idle
I have an 83 F150 5.8l that won't idle.It has been getting gradually worse so now I have to keep one foot on the accelerator to keep it from stalling.I tried to set the idle up but it doesn't work .Could this be a gas problem,like filter or dirty carb.?Or could it be ignition?when I step on it it seems to be getting gas but seems to be missing.Any ideas?
Old Apr 17, 2011 | 01:09 PM
Franklin2's Avatar
Franklin2
I would do a tune-up. New plugs, new dist cap and rotor, and while you are around under there, check all your rubber vacuum lines. While you are messing around under the hood doing a little maintenance, you might stumble onto the problem.
Old Apr 20, 2011 | 11:46 AM
rschem's Avatar
rschem
rough idle
I was taking to a friend last night.He is having the same issues with his subruban.He filled his truck at the same place I did.We are thinking it may be bad gas.
89f150billy
Jan 31, 2014 04:52 AM
jjurva
Oct 24, 2011 09:08 PM
fireman725
Bronco II
Jan 6, 2007 09:32 AM
tommyleea
Dec 6, 2006 08:35 AM
RP27G8G
22
Mar 6, 2006 05:31 PM
