Sponsored by: Real Truck
Transmission Cooler ??
Old Mar 19, 2003 | 08:52 PM
gotv10's Avatar
gotv10
I tow a 5th wheel weighing 9,200 # with my 02 F250 with PSD & auto transmission. I believe that the F250 comes from the factory with a transmission cooler. I have been considering adding an auxiliary transmission cooler. I was wondering if others pulling heavy loads have added aux. coolers, whether it is necessary, and if so, what type cooler is recommended.
Old Mar 20, 2003 | 08:02 AM
GAV10's Avatar
GAV10
The cooler the better, in my opinion. The major thing to destory a automatic transmission is heat. I installed a Hayden 679 on my truck and never have seen trans temps higher than 185 degrees F, even in the summer towing a 7,000 pound travel trailer. You may also want to consider a good synthetic fluid, I use Mobil 1. Also consider a auxiliary electric fan. I use my fan anytime the forward speed drops below 35 mph, works like a charm.
Search the "Towing" forum, lots of discussion on trans coolers there also.
Mark
Old Mar 20, 2003 | 08:34 AM
hookspacken's Avatar
hookspacken
Correct me if i am wrong, but i have heard that too cool is bad as well.
Old Mar 20, 2003 | 09:29 AM
GAV10's Avatar
GAV10
I believe the 4R100's have a internal thermal valve that only ports the fluid to the cooler when the fluid is warm/hot. Mark Kovalsky can you help us out please ?
Mark
Old Mar 20, 2003 | 11:48 AM
nafzimo's Avatar
nafzimo
I notice on the really cold mornings that my TC doesn't lock up for about 4 miles. I assume that the computer lets it slip until the fluid temps warm up.
Matt
Old Mar 20, 2003 | 06:25 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Almost. There is a cooler bypass that allows fluid to bypass the cooler when there is too much pressure. There will be too much pressure when i is cold (<0F) and the fluid gets thick in the cooler.
Old Mar 20, 2003 | 06:26 PM
Mark Kovalsky
That's exactly right.
