I looked on my library's auto repair website and it shows it on the front side of radiator support at top . From pic it appears to be on passenger side near one of the rubber topped hood alignment adjusters. I tried to copy link but it doesn't paste. Sorry.
Thanks Maz, just come back inside from checking....still can't find it. On the front side nothing on either side, back side passenger side there's a relay box with three relays inside. Drivers side is the anti-lock brake box.
CPS (Cam Position Sensor) was added starting in 1995 (1994 in California). At this time Ford changed to a 104-pin computer (it was a 60-pin) and moved the DIS functions into the computer, previously the DIS system had a TFI module as a separate unit mounted on the front of the intake manifold.
One of the reasons this part is difficult to find is that Ford (and parts suppliers) use so many different names for this part. ICM, ICA, DIS module, TFI module and who knows what else. This isn't the only part that is plagued with multiple names/abbreviations.
