injector problems
Old Apr 15, 2011 | 09:35 PM
tbomber7's Avatar
tbomber7
injector problems
just had my 03 6.0l injectors checked. mechanic found #2 and #6 were bad. he recomends replacing all 8 for $3100.00.
I can't afford that right now.
Is there any after market injectors i could buy or is it worth it? I can change the injectors my self.
Even though they found codes for two injectors could it be something else like the FICM?
Has anyone heard of doing a heat test on an FICM?
I was told to heat it up with a hair dryer or heat gun when it is cold and see if it starts better.
I have done oil flush and change, fuel filter change(both filters), tested the voltage on the FICM it is 48volts at all times.
Old Apr 15, 2011 | 10:02 PM
BLADE35's Avatar
BLADE35
I havent heard of heat test
some people have reported low ficm volts at startup and goes up to 48 volts when vehicle is warmed up
but since you have 48 volts those injectors 2 and 6 are probably bad you can just change 2
dont replace them all
I have done this on my 03 not to bad of job
Old Apr 16, 2011 | 07:23 AM
cheezit's Avatar
cheezit
just replace the failed units.
Old Apr 16, 2011 | 09:21 AM
tbomber7's Avatar
tbomber7
ok will do but i need to ait till monday cause they are closed.
Thanks for the advice i like what i am hearing.
these darn mechanics just wanna do a buntch of easy unnessesary work for top dollar. i heard this shop was really good from a friend but i am starting to have my doubts.
Old Apr 16, 2011 | 12:17 PM
cheezit's Avatar
cheezit
well I could see a point to doing the 4 on the one bank maybe.... but why sell the 4 on the other side when there is no issue.
we replace single injectors all the time.
Old Apr 19, 2011 | 11:31 AM
tbomber7's Avatar
tbomber7
Thanks guys for the advice.
did #2 and # 6 yesterday, truck runs great, tons of power.
still had to cycle a couple times this morning to get it started.
i am glad i only did the two injectors cause it is pretty easy job just takes time.
the most hassel i had was with the air cleaner but i think i have that figured out now.
oh and thank god for stubby 12mm wrenches i might go buy the ratcheting ones today that back bolt on the valve cover is tricky.
i am debating changing two more today but i will need to check the bank account first.
do you know of any addatives that will help with stiction? Or is that just a waste of money?
Old Apr 19, 2011 | 02:34 PM
rdunagan's Avatar
rdunagan
rev-x from what i have heard/read on here has been pretty good with helping the stiction problem. also try runnin 5w40 synthetic it helped my truck out a bunch
Old Apr 19, 2011 | 04:47 PM
High Binder's Avatar
High Binder
Additives are just band-aides... Just replace the two injectors, it'll cost you less in the long run.
Old Apr 19, 2011 | 07:25 PM
rdunagan's Avatar
rdunagan
what he said^^^^^ now if you are just looking to help prevent it then do what i said
Old Apr 19, 2011 | 10:03 PM
tbomber7's Avatar
tbomber7
Thanx for the info.
i already put a oil cleaner in there this morning.
hope it doesn't hurt anything.
i will change the other 6 injectors before winter, or sooner if they totally crap out.
The allmighty dollar speaks.
Old Apr 19, 2011 | 10:15 PM
rdunagan's Avatar
rdunagan
i hear ya on that one. and no it wont hurt anything. i ran it before it didnt do anything. i run a conditioner in mine every time though from bg and seems to help
Old May 3, 2011 | 01:27 AM
tbomber7's Avatar
tbomber7
got the other two injectors changed on the drivers side (only 2 hrs) thats not bad, just need $$$$ to do the other 4 i think i will just do them all at once.
It took a while for the truck to fire after i changed these two.
Is that cause i needed to prime the high pressure oil system?
Is there any way to prime it without turning it over?
Old May 3, 2011 | 02:47 PM
rdunagan's Avatar
rdunagan
nope just keep turning till it fires. of course with breaks inbetween. just air in the system. mine did that. after it starts you pretty much have to drive it like you stole it to get the air outta the system. it might have a few more hard starts but it will get better just part of it
Old May 3, 2011 | 05:57 PM
BLADE35's Avatar
BLADE35
Good deal now look at all those hard earned dollars you just saved
give it a few WOT and purge that air out
Old May 3, 2011 | 11:40 PM
tbomber7's Avatar
tbomber7
what is WOT?
