airbag light
Old Apr 15, 2011 | 08:07 PM
blk90s13's Avatar
blk90s13
airbag light
My air bag light started blinking this morning and maybe 10 minutes later is stayed on for the rest of my drive
I pulled over for a minute turned the pass air bag on and off a couple times it made it go away then it went on again once I started moving
nothing was on the passenger seat if it makes any difference
Old Apr 15, 2011 | 08:10 PM
JOHN2001's Avatar
JOHN2001
This is usually a sign that a plug or a connection has come loose
Old Apr 15, 2011 | 08:11 PM
blk90s13's Avatar
blk90s13
will look into that where is a good place to start ? under hood or inside ?
Old Apr 15, 2011 | 08:14 PM
white Buffalo's Avatar
white Buffalo
Also check you batteries. When my batteries got low or I accidently drained them down to nothing the airbag light would come until the voltage was brought back up.
Old Apr 15, 2011 | 08:18 PM
JOHN2001's Avatar
JOHN2001
I would do what Rich said too. I would start looking at the connections, more than likley start under the hood because who know what could have jumped up and knocked something loose
Old Apr 15, 2011 | 10:35 PM
blk90s13's Avatar
blk90s13
will take a look in the morning thanks for your help
Old Apr 15, 2011 | 11:16 PM
rocketman2440's Avatar
rocketman2440
Let us know what you find. Mine has been on for quite some time now, just never had a chance to dig really deep into it.
Old Apr 15, 2011 | 11:27 PM
fixnair's Avatar
fixnair
A common problem is the light that illuminates the passanger airbag switch burns out and that will cause a code to be flashed. The code is two flashes then a pause and then seven flashes. It repeats itself five times I think and then goes off 'till the next start cycle.
Old Apr 15, 2011 | 11:30 PM
VegasFordSD's Avatar
VegasFordSD
I gotcha covered bro...look no farther! Your clock spring is bad. It's located under the drivers side airbag. Mine did the same thing. It's really no big deal besides the fact u have no airbag, horn, or cruise control... I haven't done mine yet, but hear it's a pretty easy job and the part is around $50. Just remember DISCONNECT THE BATTERIES, can't imagine an airbag blowing up in your face would be a good thing.
Old Apr 16, 2011 | 08:02 AM
white Buffalo
Way to go Chris...............
Old Apr 16, 2011 | 10:09 PM
blk90s13's Avatar
blk90s13
you joking right ? loooooooool
Old Apr 16, 2011 | 10:10 PM
blk90s13's Avatar
blk90s13
you are so right my passenger air bag light did go out a couple of days ago
Old Apr 16, 2011 | 10:56 PM
timmyboy76's Avatar
timmyboy76
If anything like my truck did, you'll start hearing 5 sets of 5 beeps. Will get quite annoying, everytime you turn off, then turn on ur ride. Replace the bulb, beeps go away.
Old Apr 16, 2011 | 11:38 PM
white Buffalo
What light are you talking about? The one in the dash?
Old Apr 17, 2011 | 07:26 AM
blk90s13's Avatar
blk90s13
the one ontop the key to turn on and off the passenger airbag behind the cup holder
shark1979
1983 - 2012 Ranger & B-Series
May 30, 2010 08:57 AM
PeterAL
Feb 22, 2010 01:41 AM
robs01f250
Jan 9, 2009 09:22 PM
Bigcat350
May 11, 2007 07:10 AM
Snailboat
Sep 9, 2006 07:38 PM
