Does this replace the OEM Ignition Control Module? If it does, is it worth the investment to swap out the Motorcraft box thats attached to the inner fender?
That's an integrated sensor + module install. No reason to get it if you already have factory Duraspark (which you do). It's geared toward people with points.
