Vibration only when accelerating
Old Apr 14, 2011 | 06:46 AM
thirtyottsick's Avatar
thirtyottsick
I just bought a 2006 f150 exteneded cab w/ 5.4 V-8 and it vibrates when accelerating from a stopped position but not all the time---happens more when the wheel is turned. It definitely feels like the vib is coming from the left front side. I just got it back from the shop and the mechanic told me the vibration was stemming from the rear and that he exhchanged the fluid and added anti-friction additiver but that he expects the problem to continue. Any ideas?
thank you
jimmy
Old Apr 14, 2011 | 12:57 PM
fordman19762003's Avatar
fordman19762003
is the truck a 4x4? Also, does it have a limited slip rear end? I know there were some shuddering problems with the limited slip rearends but I think the non limited slip rearends were fine. I don't have an answer for you but I'm sure someone will be along that will help you.
BTW welcome to FTE
Old Apr 14, 2011 | 02:33 PM
MCDavis's Avatar
MCDavis
I'm with fordman19762003 on this one. It's likely the friction clutches in the LS rear end...that is assuming your truck came with a limited slip. If the friction modifier doesn't work, then upgrading to an aftermarket unit like the Detroit TrueTrac might be in order.
Old Apr 14, 2011 | 06:38 PM
thirtyottsick
ty great to b here and ty both for your replies, yes it is 4x4 and yes it is limited slip
Old Apr 14, 2011 | 08:30 PM
nsaikia's Avatar
nsaikia
I had that issue - more so when accelerating through corners. During a schedule oil change, I had the ford garage put some friction modifiers in the rear end. Problem solved.
Towmanjbo
Jul 17, 2015 07:23 PM
caedo
24
May 22, 2014 06:54 AM
ScottABickford
All Things Towing
Apr 19, 2011 11:16 AM
jjmaas
Jun 14, 2010 02:26 PM
bronk68
Jul 28, 2007 01:05 PM
