Transmission temps while towing
Old Apr 13, 2011 | 10:07 PM
Stroker 94 1/2's Avatar
Stroker 94 1/2
When I was on my trip to Texas last weekend while pulling the fifth wheel my temps got to 195 when going over the Arbuckle mountains. My temps were running anywhere from 170 to 190 the whole time. I also had the ac going. Don't know if that makes a difference? I searched and read that as long as I didn't go over 220 I'd be ok. Does this sound all right? If I get and put on a 6.0 cooler how much cooler would the temps be compared to the stock unit?
Old Apr 13, 2011 | 11:01 PM
Bonanza35's Avatar
Bonanza35
In the summer in California I never see over 168f when towing my 30 toy hauler loaded. Made a big difference on my e99. I also ran it thur the radiator which you already have. Most times this time of year I never see over 130. I do have a John Woods trans also, that helps with lock up and all.
Chet
Old Apr 13, 2011 | 11:26 PM
Franko72's Avatar
Franko72
Molon Labe
170-190 sound about normal with the stock cooler.
I added a Tru-Cool trans cooler right in front of the fan. I now see 130'ish empty, 145-160 towing 10k+ on a hot summer day. 170+ towing in stop and go traffic, or pulling a grade.
The 6.0 cooler is larger than the Tru-cool, but 3-4 times the price.
This is what i have----> http://www.transmissioncoolers.us/Me...ool-MAX-cooler
Old Apr 13, 2011 | 11:44 PM
big poppa's Avatar
big poppa
Our resident trans expert here Mark K. answered my question when I wanted to run a little bit cooler than the 180*-190* towing 7000 pounds in 90* summer heat and he said those numbers were just fine but I added a Derale cooler anyway just because, compliments of Clay(Riffraff Diesel), your fine. Here's what I got Riffraff Diesel: Derale 20,500 GVW Transmission Oil Cooler
Old Apr 14, 2011 | 07:12 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by Stroker 94 1/2
temps got to 195
There's nothing wrong with that temperature. I wouldn't spend any money to try and lower it. I just don't see any reason to run cooler than that.
Old Apr 14, 2011 | 08:37 PM
Stroker 94 1/2
Cool. Thanks guys. What temp do I not want to go over? Is it the 220 that I read about?
Old Apr 14, 2011 | 08:39 PM
Mark Kovalsky
You can go to 250F for no more than 1/2 hour.
Old Apr 14, 2011 | 08:45 PM
Stroker 94 1/2
Wow that was quick Mark. Thanks.
Old Apr 14, 2011 | 11:09 PM
Bonanza35's Avatar
Bonanza35
At 250 the fuild usually come out the front seal in every ford I ever had. Good luck.
Chet
Old Apr 14, 2011 | 11:35 PM
big poppa's Avatar
big poppa
Their you have it.. thanks Mark, reps sent..
