Help with '71 engine ID...
Old Mar 19, 2003 | 03:32 PM
79BroncoJD's Avatar
79BroncoJD
I recently got a '71 F100 I6, three on the tree, and I'm not sure if this engine is a 240 or a 300. Is there an easy way to spot the differences between the two, sans dropping the pan and looking for numbers? The valve cover sticker is there but the numbers fell off a few years ago.
F10ALLxxxxx
There is a stamped tag riveted on the door that reads 114 NET HP @ 3800 RPM.
Hope this helps, Thanks.
Old Mar 19, 2003 | 04:10 PM
BB's Avatar
BB
The VIN says it's a 240.
I don't know the I6's that well to tell 'ya, sorry.
Barry
Old Mar 19, 2003 | 06:22 PM
1968F250LWB's Avatar
1968F250LWB
Isn't the air cleaner on a 240 on the driver's side of the engine while on a 300 it is on the passenger?
Barry is correct. The fourth digit of the VIN tells you which engine it came with from the factory.
A=240CID I6 1V Carb
B=300CID I6 1V Carb
Old Mar 19, 2003 | 07:30 PM
jowilker's Avatar
jowilker
Russell, It is my understanding that like the FEs you cannot visually tell any difference between the 240 & 300. Like the 360 & 390 the stroke is the only difference.
The 223 has the initake on the drivers side while the 240/300 is passenger.
Old Mar 19, 2003 | 07:32 PM
1968F250LWB
Oops my mistake. I knew one of the sixes had it on the driver's side. Learn something new everyday. Thanks for the info.
Old Mar 21, 2003 | 06:20 AM
79BroncoJD's Avatar
79BroncoJD
Thanks for the info and responses. I have a few problems that I will be posting shortly in new threads. Thanks for the help!
hillcountryflt
Jul 18, 2016 05:51 PM
raysinvegas
19
Aug 30, 2007 02:53 PM
66FORDFAMILY
Apr 30, 2007 01:13 AM
jsmith71
Dec 7, 2004 12:04 PM
FFBruce
May 15, 2003 11:03 AM
