front main seal leak
Old Apr 13, 2011 | 07:09 PM
AceHole's Avatar
AceHole
Hello everyone, I am very new to this so bear with me please. i have a 02 f250 with 7.3 PSD 176k miles. i have a leak on the front of the engine. i have narrowed it down to the front main seal. already replaced the cam sensor with factory part and that did not help. it really only leaks when i turn the engine off, it drips pretty good for a few minutes. from the 10mm bolt behind the balancer. So i guess my question is how hard of a job is it and do i need special tools to do it? Thanks for any help
Old Apr 13, 2011 | 08:24 PM
big poppa's Avatar
big poppa
Re-read your post again. Bump..
Old Apr 13, 2011 | 09:32 PM
bulla's Avatar
bulla
If it is in deed your front main seal your in luck cause it's super easy. Only special
Tool needed is a harmonic balance pulley puller and maybe a fan clutch tool. Basicaly it's a seal inside the cover of the lpop. Once you pull the pulley, 4 10mm bolts to take loose and the cover with the seal comes right off. What I suggest is changing it with a moiling pump which is only $70 from clay at Riffraff diesel. It will already have a new seal installed in it. If you decide to just change the seal there are some
Markings on the old gears that have to be aligned. With The moling pump the gears can go on anyway. Also a good time to inspect the front cover for wear but I doubt that's an issue.
Old Apr 13, 2011 | 10:23 PM
PaysonPSD's Avatar
PaysonPSD
Maybe the bolts holding the LPOP cover are loose. Try sugging them up.
Here's an LPOP R&R THREAD if you need to replace it.
Old Apr 16, 2011 | 08:41 AM
White350's Avatar
White350
i had the same problem i changed the seal just to find out that three of the four bolts wre realy loose just try tighting them up i bet that works.
backrode570
Apr 11, 2015 07:34 PM
connork
Jun 3, 2013 03:59 AM
otter 1
Jan 10, 2003 10:00 PM
