Need help Front main seal
Old Apr 9, 2015 | 05:05 PM
backrode570's Avatar
backrode570
I have replaced the front main seal twice within a month and its leaking again seal looks torn each time looks great when installed but within the 1st 100 miles it starts leaking again. same damage to seal each time. no play in shaft. have no idea whats doing it. It's a 1989 F250 5.8 with a little over 100000 miles
Old Apr 9, 2015 | 05:15 PM
RIKIL's Avatar
RIKIL
same thing happened to me and I found the seal was bent over itself when installed. This was in a spot I wasn't able to see. I had to take a tool and carefully make sure it wasn't bent over itself, wasn't easy in the small space. If you are 1000000% sure this is good, I have nothing for you
Old Apr 10, 2015 | 01:16 AM
backrode570
The seal seem to be in right both times I also replaced timing chain cover could it possibly be off center and causing the problem
Old Apr 10, 2015 | 06:42 AM
dixie460's Avatar
dixie460
How's the surface of the crank look where the seal rides? If there's even a slight burr there it'll make your new seal leak again. You shouldn't be able to catch a fingernail anywhere on the surface. Polish it up with some sandpaper or emery cloth or something.
Old Apr 10, 2015 | 07:07 AM
bashby's Avatar
bashby
If the crank pulley is grooved you can put a speedi-sleeve on it. Be sure to lube the new seal where the crank pulley rides on it.
Old Apr 10, 2015 | 07:09 AM
backrode570
I put a repair sleeve in the last time so it shouldn't be riding on the shaft. Thinking maybe the cover is not setting right may be off center. Right now I'm lost.
Old Apr 10, 2015 | 07:10 AM
bashby's Avatar
bashby
Did you lubricate it?
Old Apr 10, 2015 | 07:56 AM
backrode570
Lubricated it and use a sleeve last time.
Old Apr 10, 2015 | 11:50 PM
jaagen's Avatar
jaagen
I guess the question is where is the seal being damaged at. Around the shaft or else where. If it's around the shaft area I would be checking all around it, or even redo the timing cover it might be pinching it some how.
Old Apr 10, 2015 | 11:58 PM
krooser's Avatar
krooser
Chinese timing cover? You wouldn't be the first guy to have problems.
BTW… that's called a timing cover seal or crank seal.
Old Apr 11, 2015 | 12:42 AM
jason90f150's Avatar
jason90f150
when I changed my seal I left the timing cover bolts loose then I put the balancer on, centered it all up then cranked it down. It was a 5.0 but Im sure its the same
Old Apr 11, 2015 | 10:55 AM
'89F2urd's Avatar
'89F2urd
if its not a huge leak, let 'er be. rust prevention at its finest.
Old Apr 11, 2015 | 07:34 PM
backrode570
Its a big leak within 100 mile it was blowing oil out of the seal. Are there alinement sleeves or shims I'm missing.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Dec 26, 2023 11:24 PM
Tuna Maniac
Mar 6, 2017 02:32 AM
ram2miller
Nov 28, 2006 12:15 AM
79beater
Sep 15, 2005 06:27 PM
bnb29
Nov 12, 2004 07:56 PM
