Sponsored by: Real Truck
CB mounting in '06 Lariat SD
Old Apr 13, 2011 | 09:42 AM
rattleNsmoke's Avatar
rattleNsmoke
I'm looking to mount my CB radio (full size Uniden bearcat) onto the lower dash where the baseball cap\garbage bag holder is located. I don't want to velcro nor floor hump mount it 'cause I don't feel like drilling holes thru the carpet. This truck will be used more as my camper tugger and not my plow truck like the '94 350 was. Some of ya'll mentioned using longer screws to replace the existing 6mm short ones that holds that panel on? It seems like I might run into difficulty due to the angle of the screws into the panel plus the weight of the CB might compromise the strength of the speed nuts backing it or the plastic they clip onto? What has been done to dash mount in that area on a new-er SD?
Thanks in advance.............
Old Apr 13, 2011 | 07:40 PM
Hemlock10's Avatar
Hemlock10
If you're concerned about the weight and materials, you could stay with the same concept you described but use thin guage steel backer plates to disperse the load across a wider area. You could also go so far as getting a larger speed nut (maybe M8) while you're out getting the longer bolts.
Old Apr 13, 2011 | 09:20 PM
smithrngr's Avatar
smithrngr
i did just that with my 01,ran longer screws.and never had a problem with weight or anything.and there holding a cobra 29ltd wx/st.which is a heavy cb and love where it is,know the feeling about drilling holes in your truck thats why i chose that area.
Old Apr 17, 2011 | 08:13 AM
rattleNsmoke
As an update:
I used 2"x6mm screws and an old 8 track sliding mount (showing my age here) to mount my CB and make it easily removable. I drilled two new holes in the slide out plate 1 7/8" inches apart from eachother and screwed the mounting plate thru the existing holes in the garbage bag holder and into the speed nuts on the back side. I ran the magnetic mount antenna cable down the backside of the cab and thru a grommet behind the rear seat. Removing the plastic rocker panel trim, I ran the coax under it then up the firewall to the rear of the mounted plate. I bought a radio Shack powerpoint plug and soldered the ends to the mounted plate hot and cold legs. I expected some engine noise and static but I was floored to find out there is NONE. The reception is as quiet and clean with the diesel engine running as when it's off! It's a nice clean install and real easy to reach while driving. My Tekonsha brake controller is within inches of the CB, so I'll report back if there's an RF conflict between the two.
Old Apr 17, 2011 | 01:04 PM
lkbrow1's Avatar
lkbrow1
https://www.ford-trucks.com/forums/1...-diagrams.html
See my post here for explanation on how I mount a CB.
chaser1602
Feb 25, 2014 03:29 PM
kuch73
13
Oct 7, 2013 11:18 AM
nikeurles3
Jan 19, 2013 07:31 AM
cdrmotorsports
Jul 26, 2010 09:17 PM
hackwillie
Mar 27, 2007 12:43 PM
