Starter Replacement
Old Apr 13, 2011 | 08:08 AM
hateful1968's Avatar
hateful1968
Starter Replacement
I was told I would need a special wrench to get to the top bolt. Is this true?
2003 E-350 7.3 diesel original starter with 657821 miles. Engages then disengages and spins. Takes several tries to finally start. Before I buy the new starter, want to make sure I have the correct tools.
Old Apr 13, 2011 | 08:51 AM
fast_st's Avatar
fast_st
Nope, you can use a standard wrench but you have to keep flipping it, takes forever. I've had good luck with a swivel head ratchet, the craftsman is the lowest profile, that and a short 6 point socket, angle the handle back and you'll have 2-3 clicks worth of swing.
Old Apr 13, 2011 | 08:55 AM
hateful1968
That's what I was hoping to hear. Never had to use anything special, other than a swivel, on any starter before.
Thanks.
Old Apr 13, 2011 | 09:27 AM
Nick 99's Avatar
Nick 99
You might want to find a good rebuild shop to have your starter rebuilt instead of getting a poor quality replacement. There seems to be lot less than junk out there being sold from large suppliers that wont last as long as your original. Do some searches on this forum and read up.
Nick
Old Apr 13, 2011 | 01:08 PM
fast_st's Avatar
fast_st
Nick
Solid advice, this issue could even be a bad on the starter solenoid, a cheap repair at a rebuilder.
dyoungen
27
Sep 9, 2012 06:16 PM
RÖENTGEEP
Mar 27, 2007 03:44 PM
Corbin18
1978 - 1996 Big Bronco
Aug 27, 2004 08:55 PM
merlin4044
1983 - 2012 Ranger & B-Series
27
Oct 29, 2003 07:28 AM
