column drop
Old Apr 12, 2011 | 04:29 PM
MCarlson's Avatar
MCarlson
column drop
I finished my column drop today. I only needed two inches of drop wanted something a little different. The connecting rod I used is from an old 'Hercules' industrial motor. I cut it about an inch and a half above the big end and drilled a 1/4" hole through the beam. I cut two small 'L' brackets out of 3/4" angle iron and welded them to a flat piece of 1/2" stock about 5" long. I bolted it to the stock steering mount holes on the bottom of the dash with a piece of rubber in between for a gasket. Now on to the brake pedal.
Mike
The pictures are in my album and I'll to add them here.
https://www.ford-trucks.com/forums/p...02642726&thumb
Old Apr 12, 2011 | 04:35 PM
sdetweil's Avatar
sdetweil
very neat!..
haven't seen anything like that
Sam
Old Apr 12, 2011 | 05:13 PM
Moe Craig's Avatar
Moe Craig
MCarlson,
That looks great... Great idea! and nice work...
Old Apr 12, 2011 | 05:56 PM
seanmconroy's Avatar
seanmconroy
verry nice
That would look class if you got that chrome plated. Or even a lick of paint. Great job bud. Keep it comming.
Sean m Conroy
Grande Cache, Alberta
Old Apr 12, 2011 | 06:04 PM
MCarlson's Avatar
MCarlson
Thanks guys. Luckily my welding skills are blurred in the second picture.
I haven't decided on a finish yet. It actually looks pretty good as is. The truck will be cream and maroon. I still have to pick up a mount to use on the floor. At least it's starting to look more like a truck than just a big go-kart frame.
Old Apr 12, 2011 | 06:59 PM
Wayne S's Avatar
Wayne S
That is a very cool idea.
Old Apr 12, 2011 | 07:14 PM
Mervy49's Avatar
Mervy49
What a great idea, looks awsesome.
Old Apr 12, 2011 | 09:34 PM
BACAGrizz's Avatar
BACAGrizz
Cool. I like it a lot.
Old Apr 13, 2011 | 05:35 AM
hellfirejim's Avatar
hellfirejim
That looks neat. The best part about it is that it is different and your idea. Well done.
jim
wasa 1500
Jan 30, 2013 07:23 PM
jbarefoot
13
Feb 8, 2012 05:30 AM
hotfalcoon
26
Aug 20, 2011 06:54 PM
makomaker
34
Feb 7, 2010 10:06 AM
nissandoc
56
Sep 28, 2009 07:04 PM
