fuel pumps
Old Mar 19, 2003 | 12:48 PM
bscott00's Avatar
bscott00
fuel pumps
i have an 85 f150 w/ a 302 efi. it's running very rich and acts like it's flooding out. my question is , if the fuel pump is bad could it be pumping too much gas through the system? it seems like it wouldn't be getting enough gas but i'm not sure. i'm running out of ideas.
Old Mar 19, 2003 | 03:16 PM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
fuel pumps
i would asume that its a carb motor right?
maybe a float adjustment is needed
Old Mar 19, 2003 | 10:21 PM
E150X's Avatar
E150X
fuel pumps
My 84 4.9 the choke would stick and set off the smoke alarm inside the house from the black exhaust. My 80 302 did the same thing.
Old Mar 20, 2003 | 12:32 AM
chris93's Avatar
chris93
fuel pumps
you need to check the fuel pressure regulator,pull the vac line off of it,if fuel comes out its bad.if it is bad,you also need to change your oil.
anthrax91
Aug 29, 2014 05:08 PM
knuckleheadrider
Apr 20, 2012 06:45 AM
flatheadjohn
Dec 2, 2009 01:15 PM
master link
Aug 24, 2006 11:19 AM
madmatt
Mar 17, 2005 06:17 AM
