fexplate
Old Apr 12, 2011 | 01:50 PM
ladelld33's Avatar
ladelld33
fexplate
i have an 84 F150 with a midly built 351w in it. i'm trying to swap my C4 tranny out for a AOD which flexplate will i need for this swap & yes i'm going to rebuild it to handle the power of the 351w. i need the overdrive to take some trips with it.
Old Apr 12, 2011 | 03:53 PM
Kemicalburns's Avatar
Kemicalburns
well unless someone else put the C4 in there that truck should have a C6.
you want a flexplate from a late 80's crownvictoria running the 5.8/aod combo and 164 tooth.
a new flexplate shouldnt be more then $60-70 at most.
Old Apr 13, 2011 | 05:29 AM
ladelld33's Avatar
ladelld33
well the truck had a 302 in it and we built the 351w from a bare block that the builder had. the transmission shop verifird that it was a C4 tranny. should the flywheel be the 28oz correct cause i just put a new one in during the build. now i have to find the crown vic
Old Apr 13, 2011 | 09:12 AM
Conanski's Avatar
Conanski
The correct flexplate is 28oz, 164 tooth, and will be stamped AOD specific. The difference between it and the other varieties is with the front to back offset when mounted on the crank, the C6/E4OD flexplates have too much offset which pushes the TC back too far and that will result in immediate death of the transmion due to metal on metal contact inside the oil pump.
Old Apr 13, 2011 | 10:06 AM
Kemicalburns
does your auto tranny have a removable bellhousing?
302 uses a 50oz imbalance
351w uses 28oz imbalance
Old Apr 13, 2011 | 01:31 PM
ladelld33's Avatar
ladelld33
not sure if its a removable bellhousing or not. thanks Paul for that info. another question which cross member do i use i know the one that i have now won't work would it? if there's anything else you guys could tell me about this swap please do. my wife is ready for me to finish up so we can cruz down by myrtle beach in it..
Old Apr 13, 2011 | 02:07 PM
85e150's Avatar
85e150
C4 has removable bell. AOD is integral.
As for cross member etc, see the tech info here. They also have mounts for the cross member.
TCI - Ford AOD, AODE and 4R70W
Critical dimensions, including bell to mount:
TCI - TECHNICAL INFORMATION: Transmission Dimensions
Old Apr 13, 2011 | 03:02 PM
Kemicalburns
i would get the crossmember from an 85-86 bronco with a 5.0/AOD combo.
like 85 mentioned if the tranny you have is infact a C4 the bellhousing is removable just like the older Manual trannies. if its not then you have a C6
FLUSHED UP
Jun 20, 2010 03:54 PM
alz
Oct 11, 2006 09:33 PM
uncle junk
Engine Swaps
Mar 10, 2006 06:23 AM
1979ford
Engine Swaps
18
Jan 24, 2005 03:02 PM
frogger01
Mar 15, 2001 06:08 PM
