351m swap
Old Mar 7, 2006 | 12:45 AM
uncle junk's Avatar
uncle junk
Smile 351m swap
im swaping out a 351w from my 86 f350 and i want to put a 351m in its place what do i have to change like radiator wireing etc
Old Mar 7, 2006 | 02:41 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Why would anyone want to make that swap????
Old Mar 7, 2006 | 02:43 AM
ford390gashog's Avatar
ford390gashog
seems like a backwards swap. you also need a new trans.
Old Mar 7, 2006 | 08:24 AM
uncle junk's Avatar
uncle junk
why not swap it out isint the 351m a bigger engine what is the comparision to the351wi dont know much about the 351m but i have one with 12,000 miles on it with a two wheel drive trans but i m looking for a 4wd trans
Old Mar 7, 2006 | 01:01 PM
Kemicalburns's Avatar
Kemicalburns
the 351m is very restricted. gets horrible gas mileage and the power output sucks unless its been heavily gone thru.
stay with the 351w and rebuild it or find a wrecking yard 351w and use your parts. easier, less to change over
Old Mar 8, 2006 | 02:06 PM
Matts72's Avatar
Matts72
Welcome to FTE!
There isn't anything wrong with the 351M, but for the amount of work you would have to do, it would probably be easier to rebuild your 351W. As stated above, you need a different transmission or at least a bellhousing.
Good Luck!
Old Mar 9, 2006 | 12:14 AM
Torque1st's Avatar
Torque1st
Posting Legend
The 351M is an OK engine, not a good or even great engine, -just OK. The 351M was not really restricted tho unless you count the long rods and tall heavy pistons. It was free breathing but not free revving. The 351W had the same bore and stroke but will turn higher RPM's better even tho it was "restricted" in the head breathing department which resulted in the nickname "Wheezer". Check with the 351W forum for more information on how to improve your existing 351W engine. There are lots of nice things available for that engine. You can swap in a 351M but many changes are required as noted above and many more. Stick with the 351W, it was a "good" engine and with mods can be a "great" engine.
Old Mar 9, 2006 | 05:26 AM
onebad40willys's Avatar
onebad40willys
you could swap the 351m heads with the 351w. After u do the proper mod's to the 351m heads
Old Mar 9, 2006 | 09:17 AM
Kemicalburns
why go thru all that trouble. then you gotta figure out how to get the intake to work what manifolds to use etc.. better head choices out there for decent prices.
Old Mar 10, 2006 | 06:23 AM
onebad40willys
the 351c head's would be better than the 351m & 400 head's. And ford still or did make a aluminium version of it. I think it's for the svo block but i dont have a current performance part's book. I think the 351w require's spacer's to use the 351c/m & 400 and 302 boss intake's. Header fitment could be interesting on a mid-80's ford.
rsalter66
May 28, 2007 01:35 PM
warecreek
Jan 25, 2006 10:08 AM
jec27
Oct 20, 2003 08:32 PM
FordRacing2
15
Aug 12, 2003 09:39 PM
canadianfordman
Jan 22, 2001 12:40 AM
