CDR question
Old Apr 12, 2011 | 01:10 PM
Fordownsall's Avatar
Fordownsall
CDR question
I got my CDR valve out and I cleaned it out with gasoline. I remember reading but I couldn't find it again.. how to test it by suckin and blowin and stuff? I don't really see anything rubber in mine or feel anything rubber in it. Should some kind of rubber be easily visible? just called ford and they said its 60 bucks I wanna make sure this thing is bad before I throw my money away. how to test it would be appreciated thank you
Old Apr 12, 2011 | 01:37 PM
snaponprofile's Avatar
snaponprofile
If its original, its gonna be sooner or later when it goes anyways. Your lucky your dealer has it for $60, mine was $90. I would just get it from your dealer and replace if it were me.
Old Apr 12, 2011 | 01:38 PM
vfelix702's Avatar
vfelix702
i would like to know as well maybe someone can take a pic of a good 1 and a bad 1 so see the diffrence
Old Apr 12, 2011 | 01:43 PM
snaponprofile
The difference is inside. A pic wouldn't help.
Old Apr 12, 2011 | 01:53 PM
Fordownsall
.... i don't have the money to waste right now... If its good I'm going to throw it right back on... if its bad... ill replace it. I just want to know how to test it and if I'am supposed to visually SEE rubber inside of it.
Old Apr 12, 2011 | 01:57 PM
vfelix702's Avatar
vfelix702
Ah got ya so how or what is a "testing Procedure" other than visible oil on the intake pletum?
Old Apr 12, 2011 | 02:00 PM
snaponprofile
You should see part of a coil in there and you should feel some rubber inside(bottom I think). If you don't have the money, just run it and get a new one when you can. Its not gonna hurt it to run for a little while, just might leak a little oil into the intake. If you don't replace it, your HG's may fail, if you would rather save $60 and risk the HG's blowing, go ahead. I'm more of a replace it before something breaks guy.
There is a small hole in the CDR back cover, ensure it is clean and open. If black chunks of rubber are visible in the intake, on the screen then the rubber membrane has disintegrated, replace the CDR.
-cdnsarguy, on diesel stop.
Old Apr 12, 2011 | 02:05 PM
Fordownsall
found it:
https://www.ford-trucks.com/forums/9...-problems.html
josh'sdeisel
15
Sep 28, 2011 09:27 PM
newr
17
Aug 5, 2009 10:08 PM
RunRed
Sep 17, 2007 07:25 AM
Danny_Ocean
Mar 30, 2006 06:30 PM
DMAN
Nov 15, 2004 10:03 PM
