Question about tuned OBS.
Old Apr 12, 2011 | 10:55 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Ok so we just got AE working. Max boost by the gauge was 12 and most boost saw on the MAP sensor was 13. ICP pressure was holding 3,200 at 40% duty cycle (Jelous). Were going to hook up out boost leak dector now and checking fuel filter now.
Old Apr 12, 2011 | 11:40 PM
oldbird1965's Avatar
oldbird1965
Originally Posted by deadsenator
I can blacken the road behind me with my stock sticks on Tony's tunes. I wonder how that will change on Stage 1's.
I also have TW tunes and with my baby beans (130cc) I can also blacken out the road behind me. I had him reburn it and it still smokes , I would love to get all the power I can out of my mods without pouring black smoke out. Time to check with another turner, PHP is sounding good. I know most people think its cool to blow black smoke and I do too, when I want to. Most of the time pulling my 5th wheel I think its embarrassing and wasteful. People just think I have a piece of shi! 15 year old trunk!
Old Apr 13, 2011 | 02:51 AM
deadsenator's Avatar
deadsenator
I agree, Glenn. I'm not a big coal-roller, either. The only time I really enjoy it is when I have a tailgater...then anything goes.
I'd rather have the power than unburnt fuel. I am right on the verge of plonking down for Stage 1's (AC), so I'll figure it out after that.
Old Apr 13, 2011 | 06:07 AM
Robbgt's Avatar
Robbgt
Originally Posted by Robbgt
WAG disconnect the MAP sensor and see if that helps
Originally Posted by tjbeggs
Try unplugging the connector on the MAP sensor and run the truck.
Try this yet?
Old Apr 13, 2011 | 08:12 AM
Cratos's Avatar
Cratos
you will need to get his comp reflashed if it has never been done to get the com port to work right. we had to on my buds eary 96 anyway.
Old Apr 13, 2011 | 10:03 AM
superduty4x4's Avatar
superduty4x4
Give Cale at Tyrant Diesel a call and see what he can do for you. Cale's dad is Brian of BTS and he's been doing this a while but he just started his own company. Tyrant Diesel.
Old Apr 13, 2011 | 12:10 PM
weekendwarriorfsw32
Master of Strokes
Try this yet?
The air tube or the electrical?
Old Apr 13, 2011 | 12:13 PM
superduty4x4
Both! You've got to start somewhere. Unplug the MAP sensor (electrical), if the truck runs better then inspect the hose for blockage. If you find none, replace the MAP sensor.
Brown Falcon's Avatar
Brown Falcon
Unplug the electrical, it will put the truck in "default" map mode, if it runs better the map sensor is bad.
And what Chase said, check for blockage in the tube. If you want to replace the tube air compressor hose works well.
Old Apr 13, 2011 | 12:26 PM
Robbgt's Avatar
Robbgt
^ What they said
Old Apr 13, 2011 | 12:58 PM
pjwoolw's Avatar
pjwoolw
Nick is his MAP sensor black or gray?
Old Apr 14, 2011 | 06:25 PM
weekendwarriorfsw32
Master of Strokes
Well yesterday we un plugged the map sensor and it seemed to run better and we almost got 15 psi out of it. Pete I forgot what color it was I will look later today.
Old Apr 14, 2011 | 06:27 PM
  #28
pjwoolw's Avatar
pjwoolw
Gray is good. Black is bad. If its black it should be replaced. But even if it is a gray one it could have failed.
Old Apr 14, 2011 | 06:43 PM
  #29
weekendwarriorfsw32
Master of Strokes
Ok it's a black plug, gray body.
Old Apr 14, 2011 | 06:49 PM
  #30
pjwoolw's Avatar
pjwoolw
If its running better with it unplugged my guess is its taking a dive. You sure the hose is OK?
RandomNewGuy
Nov 13, 2015 09:05 AM
caedo
22
Sep 18, 2014 05:19 AM
Canadian7.3
Feb 18, 2014 09:08 AM
ttttmaxx
May 4, 2010 11:29 AM
crack
Nov 8, 2006 12:27 PM
