Hydra tunes + one more?
So I have a buddy who.... (great intro to a story right? )... who has been working on upgrading his 02 SD. He doesn't really understand much about it, but iv been helping him through the modification process and i think my PMS was a little too contagious. To make matters worse, he has more money to spend than me! (Tech school tuition versus private liberal arts college tuition) Long story short, he is to the point where he wants to buy a chip. I have him mostly sold on the Hydra, and he is all for it except the fact that PHP doesn't offer a "smoke tune". Now before you all come at my throat for saying the word smoke, let me tell you that I have tried to convince him that it is bad and not really all that cool. But to no avail; he insists on having something to show off to his other buddies (who do think it's cool to roll coal). PHP doesn't suggest that he get the 140 extreme because he has PMR's which i understand. Sucks to suck. So no smoke that way, and no smoke tune either, so no smoke at all. So my final question is: Would other tuning companies like Swamps, TW, BTS, Gearhead, etc. send individual tunes (a smoke tune specifically) to him to put on his hydra or would he have to purchase a "whole set" of 6 tunes like you do when reburning a TS 6pos?
That's all, and a quick response would be awesome because he his very antsy about ordering this thing
Thanks!!!
Thanks!!!
Gearhead won't do it, says so right on their website...
Tell your buddy he needs to stop overcompensating for the toothpick in his pants... Rolling coal just makes you look like an @$$ and is the major reason we have all this emissions bs on diesels today. I very seriously doubt you will get anyone on this forum to help him roll coal...
Look you don't need a smoke tune to blow smoke. Put in a tune that calls for more fuel than your sticks can handle ie a 140 tune for most people, turn the a/c selector to max and mash the pedal to the floor. I do this only on rare rare occassions. I have gearhead tunes and can blow well we'll say "enough" smoke out the pipe.
I had a "smoke" tune from my previous tuner and it never smoked that much, just a puff then cleared right up....
Just try to convince your buddy that spewing smoke out of the tailpipe is for teenagers and gives all of us a black eye. If he's really that interested in maybe he should be doing the research....
Gearhead does write tunes for the Hydra however they/Matt will not write a smoke tune. And yes you can load several different tuners tunes on the chip but it is recommended that you shut by hen truck of when switching between tunes that are written by different companies. I don't remember who but someone had undesirable ....not damaging.....results when doing this.
We can speculate about this all night long (and probably for the remainder of the week) or I can stop it right here.
First things first, ANY calibration in the advertised horsepower range of 80-120 for a stock truck (and yes, your buddy's truck is stock) is going to smoke when the accelerator pedal is depressed fully and quickly. There's not a "smoke" tune out there that will make copious amounts of intersection stupidity after 1800-2000 RPM because the injectors simply cannot inject enough fuel. Once the turbocharger has finally mustered up enough boost to catch up with the fuel being injected, the big black cloud goes away and you're left with a haze that is identical to the aforementioned 80-120 calibrations. There's only so much fuel available and anything over an advertised 80 RWHP increase is just causing a drop in high pressure oil pressure.
Secondly, the ability to use/switch between different tuning company offerings is only limited by that company's willingness to work with you. The switching between different companies' "tunes" can and will be seamless as long as the same base calibration is used for that particular set of calibrations. For example, if you use PHP's tuning for a 49-state 99.5-01 vehicle, you'll use VRAA6S3. If you decide to purchase from another vendor a second set of calibrations but that company uses or writes for VNAA8U5, then you'll end up with issues when switching. Once switched (and after the stumble or stall), the truck will run fine on either one. As long as you know what you're using for calibrations and both (or all) vendors know what's being used, you won't have any issues. There's nothing wrong with mixing calibration base strategies either. You're not going to hurt anything by causing a PCM reboot...other than it's something that should be avoided if you're in traffic or under a driving condition where intentionally causing a potential engine stall isn't going to get anyone killed.
