Okay, some of you may recall a while back I had fuel gelling issues with my truck, and a few months back I started to notice it running kind of funny so I bought a tire pressure gauge and tested the fuel pressure. It was 108psi at the time. Fast forward to today, I hadn't had the time or ambition to mess with it but finally got around to it today. Pulled the fuel bowl, completely disassembled it, disassembled/cleaned the FPR and threw all new O-rings at it. Nothing looked funky or out of place, no shim in the FPR, nothing unusual at all. I took the fuel cap off and blew compressed air through the return line, no blockage at all. Reinstalled the fuel bowl, fired it up... 100psi. Now that I think about it, the one thing I forgot to do was blow compressed air back through the line that goes from the bottom of the FPR to the bottom of the fuel bowl. Is it worth my time to pull the FPR off tomorrow and try that? Any other suggestions?
96 CA emissions F350, bone stock motor and fuel system.
When I tested it the first time, the gauge was brand new out of the package but I didn't go buy a $20 gauge knowing I'd be trashing it by using it for fuel psi testing. I guess the next step is to get my EV2 fuel psi gauge installed and see what it says. I'm assuming I can just remove the OEM schrader valve and put the sender for the gauge in its place?
You should be able to thread it into the schraeder fitting ..
i dont see the stock pump being able to put out that kind of pressure. i think you would have destroyed the orings by now. but 100lbs is a scary thought!
I know y'all think I'm nuts but I wouldn't chit you guys, you're my favorite turds. I'll try to get the gauge installed and see what it says and go from there.
Pump will live a shorter life at this pressure.
How would 100psi destroy the o-rings????
At 100 psi you have a problem in the fuel system.
Most common would be an oil leak.
Does the high Fuel Pressure relate to the CA Emissions at all?
CA models are rumored to run higher pressures than the 49 state models but 100psi is still a bit excessive.
Bill
No sign of oil contamination in the fuel when I drained the bowl. The fuel was green, not dark at all. Looked similar to pickle juice. Maybe that's because I drained it into a pickle jar...
