Rough Itle
Old Apr 11, 2011 | 04:43 AM
diesel241's Avatar
diesel241
Rough Itle
I am new to the 7.3 world. I got rid of my 2006 6.0 wich was a nice truck to drive and never gave me any problems. Now i am driving a 2000 f350 lariat le drw wich is also a nice truck but much different. So my question is what are the things i am going to notice (one being the rough itle) that i shouldnt worry about? Is the rough itle normal or is something wrong? Thanks
Old Apr 12, 2011 | 12:00 PM
cprice7.3's Avatar
cprice7.3
When my ICP sensor started going bad the truck started running pretty rough. May want to check that. My knowledge is fairly limited, but Hope that helps.
Old Apr 12, 2011 | 12:24 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
A few things that are different is, you don't need to worry about head studs/gasket going bad, you don't need to worry about the EGR giving trouble, don't have to worry about the variable vane turbo giveing you problems. You should hear a little louder idle but not rough idle.
Hang out and read about how much we love the 7.3.
Old Apr 12, 2011 | 12:41 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Do you know if you have the Gray recall CPS in the truck? If so it will cause a little rougher idle than the Black original.
Old Apr 12, 2011 | 03:06 PM
clintbonnie's Avatar
clintbonnie
You can try and disconnecting the ICP at the plug.. and see if it improves your idle.. If so, I would replace the ICP..
Old Apr 13, 2011 | 12:17 PM
clintbonnie
Here is more info on ICP sensor.. note: check it for oil leakage after removing electrical plug.
https://www.ford-trucks.com/forums/1...placement.html
Speed-demon
3.8 & 4.2L V6
Apr 17, 2014 09:01 AM
FarmBoyNation6.9
Large Truck
Jan 3, 2014 10:26 PM
cabloom300
18
Aug 30, 2011 05:45 PM
Duct Tape Racing
32
Jun 16, 2011 12:05 AM
Mechanix185E
May 7, 2010 08:23 AM
