Glow plug check
Old Apr 10, 2011 | 11:16 PM
eatont9999's Avatar
eatont9999
Glow plug check
Hey fellas,
I pulled all my glow plugs this afternoon and luckily they were all Berus. I don't know how old or how many miles are on them. I would like some opinions on that. I also noticed that the plastic connectors broke or crumbled when I removed them from the plug leads. I am thinking of buying and keeping a glow plug harness on hand. There is nothing wrong with the metal connectors, though.
I will post pictures of one plug from the front driver's side. They are all in the same condition. I am also going to make a separate thread on my IP. I want to know if how old it is and if I should replace it. I get about 16.28 MPG on the highway.
Old Apr 10, 2011 | 11:17 PM
eatont9999's Avatar
eatont9999
Old Apr 10, 2011 | 11:18 PM
eatont9999's Avatar
eatont9999
OK, Batman, big pictures ^^
Edit: Pictures have been re-sized, Robin.
Old Apr 10, 2011 | 11:25 PM
oreocreaming's Avatar
oreocreaming
natural swelling from lots and lots of heat cycles. just grab a new set. theres a thread around here that a guy found where you can buy the bullet connectors to make your own harness for a lot less. and as far as the ip, thats up to you. still fair mpg. what engine, tranny and gears do you have? that will let us know if its on the higher side or lower side of your mpg range
Old Apr 11, 2011 | 12:21 AM
eatont9999's Avatar
eatont9999
Yeah, I thought they were original. I am just glad I didn't find Autolites in there. I have never had a problem starting this truck so these will make an excellent backup set.
Check out my IP post. I included more info than is most likely necessary but it's all good stuff. I'll have to pickup a new set of Berus before my trip. At least I can rest assured that they won't swell on me.
Check out my post on the IP; more info there.
Old Apr 11, 2011 | 03:24 AM
carolinaranger90's Avatar
carolinaranger90
There's a few things I would like to point out for you man.
If you end up replacing the plugs, ONLY BUY DZ9 plugs, autolites tend to over swell, causing you to have to remove the head for safe removal.
I've heard the same for other brands.
And the way to check them, is with a test light, I can do a pic by pic process for you today if you would like, I think I have a few dead plugs, so I won't be going outta my way.
Old Apr 11, 2011 | 05:21 AM
Brandon1986's Avatar
Brandon1986
Anybody ever tried to remove overswelled gp's by loosening them getting them to stick in the hole then fire up the truck and let the compression do the rest??? I have a few that need changed that are over swelled Im thinking about doin that. Let it be noted that I have a spare freshly rebuilt engine sitting on a stand if it turns into a catistrophic failure.
Old Apr 11, 2011 | 06:06 AM
carolinaranger90
I wouldn't advise it Brandon, I just see threads being torn up, or worse, regardless of having another ready-to-install IDI.
These motors have a 21.5:1 Compression, that's a lot of pressure in a slightly larger than 4" bore, with very little escape, you could be blowing a good chunk outta the head with that.
While Fire seeks a fuel source, Pressure seeks a way out, which ever way possible.
Old Apr 11, 2011 | 09:33 AM
eatont9999's Avatar
eatont9999
I have been wondering about what would happen if you did that for a long time. I never mentioned it but I would like to know if that is a viable way to get the stuck plug out. I guess you have to think about the suction forces as well.
dtgl90vt
15
Oct 19, 2012 08:25 AM
blazinjames
Jun 22, 2012 04:23 PM
Pitcrw6
Oct 3, 2010 05:20 PM
Krusty
Feb 6, 2009 05:38 PM
ghunt
Dec 23, 2008 10:10 AM
