downpipe
Old Apr 16, 2011 | 08:41 PM
  #31
Talyn's Avatar
Talyn
Originally Posted by oldbird1965
You can't be that slow with your mods. Your just being modest. LOL
I'm an old man.
Sloooow
Originally Posted by whitepittbull
well its on and sounds like a hole different truck no major problems diamond eye two piece must be the way to go i think
Yeah, 2 piece is way to go. glad your liking it.
Old Apr 17, 2011 | 10:38 AM
  #32
BadDogPSD's Avatar
BadDogPSD
I thought intalling the 3" MBRP DP was a royal pain, worst project ever. Until now as I try to install a 3 1/2" DP for my H2e. I think my truck is one of the special "engine back, cab forward" models!
Old Apr 17, 2011 | 11:06 AM
  #33
Talyn's Avatar
Talyn
Neals H2E pipe looked like a royal PITA.
Old Apr 17, 2011 | 11:34 AM
  #34
BadDogPSD's Avatar
BadDogPSD
I wish I had the equipment needed to pull the transmission so I could get at it with a BFH... so far I've tried 2x4"s, pipe, pry bar, porta power. It seems like it's moved as far is it's going to move.
I've read about guys moving the engine forward, mine won't budge. I'm thinking of trying to move the cab back next.
Old Apr 17, 2011 | 11:38 AM
  #35
Talyn's Avatar
Talyn
I bought a trans jack.
Made life easy.
need to replace the turny ***** with nut's so you can put a wrench on them though.
There is too much slop in the tilt stuff, so i could never get it where I wanted it.
Old Apr 17, 2011 | 11:45 AM
  #36
JamesHajek's Avatar
JamesHajek
Have you cut the pinch weld in strips and then pushed it back with the portapower?
Old Apr 17, 2011 | 01:38 PM
  #37
BadDogPSD's Avatar
BadDogPSD
Yes, did that when I put the 3" DP in... For some reason my truck just does not have any room between the engine block & firewall.
Old Apr 18, 2011 | 12:07 AM
  #38
oldbird1965's Avatar
oldbird1965
Hang in there Craig, when I put my 3 1/2 in I had a hell of a time. I used a porta power and boards like you are using. Keep trying, it will crush in!
Old Apr 18, 2011 | 01:19 PM
  #39
BadDogPSD's Avatar
BadDogPSD
Thanks, I'll keep at it!
Old Apr 19, 2011 | 12:32 AM
  #40
oldbird1965
Originally Posted by Talyn
I'm an old man.
Sloooo
You don't look old in your picture, slow man. You have to quite drinking that keystone and get your speed back.
Old Apr 19, 2011 | 06:34 AM
  #41
Robbgt's Avatar
Robbgt
... You have to quite drinking that keystone and get your speed back.
Just don't quit that stuff cold turkey! last time i tried that, the 'ol body dang near shut down
Old Apr 19, 2011 | 07:39 AM
  #42
Talyn's Avatar
Talyn
I'm useless without my daily beer.
It just doesn't feel right. haha.
Went and got corona and a pizza last night.
Old Apr 19, 2011 | 10:12 AM
  #43
oldbird1965
Cute looking dog Robb. I suppose its the boss like mine is!
Old Apr 19, 2011 | 12:21 PM
  #44
Robbgt's Avatar
Robbgt
Thanks Glenn, Yes sir he is the boss! Loves to ride around in the PSD
Old May 4, 2011 | 11:43 PM
  #45
MONAVIERONJON's Avatar
MONAVIERONJON
Does the Diamond Eye DP require any modification or would it be installed as received pertaining to the length compared to the OEM length?Assuming using the remaining exhaust system as a bolt on install.Just wonderin for when mine shows up here soon.THnkx
