downpipe
Old Apr 14, 2011 | 05:52 PM
redman84's Avatar
redman84
Or you'll be lucky like me. I had the portapower on standby but I only had to bend the pinch weld like 1/4" or less. I also only needed one cut on my old DP to get it out. Took less than an hour start to finish. NOT how most of my projects go! Good luck
Old Apr 14, 2011 | 06:20 PM
superduty4x4's Avatar
superduty4x4
I may have spoke to soon, I think I have a slight bit of firewall contact at around 22mph. Not sure what I can do about it since the porta power was just trying to rip the cab off the frame instead of bend the firewall but it's pretty minor so I'm not going to get too worried about it. I think my truck is one of the minimal clearance models.
Old Apr 14, 2011 | 08:32 PM
JamesHajek's Avatar
JamesHajek
How close to the uppipe is it? Might just need to shift/twist the top part of the downpipe a bit to get it away from the firewall and towards the motor a little more.
Old Apr 15, 2011 | 11:39 AM
Oslo's Avatar
Oslo
How can you tell it is hitting ? What if you still have the foil insulation intact can you contact that ?
Old Apr 15, 2011 | 11:42 AM
JamesHajek's Avatar
JamesHajek
Yes, You will feel it inside the cab and hear it. It makes a godawful noise when its rubbing.
Old Apr 15, 2011 | 12:09 PM
oldbird1965's Avatar
oldbird1965
Mine did it most often on right turns for some reason.
Old Apr 16, 2011 | 09:47 AM
whitepittbull's Avatar
whitepittbull
heading to the shop to put the down pipe and new 5 inch exhaust on the beast today thanks for all the info you guys are great folks thats whats wrong with the rest of the world nobody wants to help another anymore all bout themselves thanks again
Old Apr 16, 2011 | 09:57 AM
Talyn's Avatar
Talyn
Sounds like you have some motor mount issues like I do.
My fan somehow hits the shroud occasionally, but I cannot get my engine block to move at all, though I feel it moving when driving.
My DP is tight, but if you get it in there right, It will be golden.
I have about 1/4 or less clearance around it.
Dry fit everything in place before tightening it for sure!
Its a PITA to get in there, but you can get it.
Old Apr 16, 2011 | 10:42 AM
oldbird1965
After adjusting the DP, I don't get that noise anymore Talyn.
Old Apr 16, 2011 | 11:01 AM
Talyn's Avatar
Talyn
I get no noise myself, thankfully.
I still wanna know how my fan rubbed on my shroud where it did though.
Old Apr 16, 2011 | 02:44 PM
oldbird1965
Must be when you had it in extreme setting and nailed it in a lower gear!
Old Apr 16, 2011 | 04:24 PM
Talyn's Avatar
Talyn
My truck is slow, whatchoo talkin about? :P
Old Apr 16, 2011 | 06:37 PM
  #28
oldbird1965
You can't be that slow with your mods. Your just being modest. LOL
Old Apr 16, 2011 | 07:39 PM
  #29
whitepittbull
well its on and sounds like a hole different truck no major problems diamond eye two piece must be the way to go i think
Old Apr 16, 2011 | 08:40 PM
  #30
fordpride's Avatar
fordpride
Good to hear you got it in how long did it take you
