Power steering pump pulley?
Old Apr 10, 2011 | 07:42 PM
blucollar4xford's Avatar
blucollar4xford
This is actually on a ranger, but the donor pump is from an 84 f150, so I figure it's legit
changing out the ps pump and I have the pulleys off (one is sepentine, the other, v-belt). What do I need to reinstall the pulley on the pump? Would I have to remove the bracket and all and have it pressed back in, or is there a way to do it on the truck?
Old Apr 10, 2011 | 07:56 PM
Franklin2's Avatar
Franklin2
How did you get the pulley off? The special tool you used to get it off should put it back on also. If you did not use the special tool, the pump and the pulleys are probably no good now.
Old Apr 10, 2011 | 08:16 PM
blucollar4xford
I got the puller (adv auto special) but I can't see how it could ever get the pulley back on...I'm actually embarassed to be askin lol
Old Apr 10, 2011 | 08:31 PM
fox3698's Avatar
fox3698
clean up the shaft with some steel wool or a scratch pad.
clean the inside of the pully where the shaft goes.
use the bolt that used to pull it with.
there should be a nut and some washers with it.
put the nut on the bolt and spin it up by the head of the bolt.
put a couple washers on next, then thread the bolt into the shaft.
draw the nut up to the washers and use two wrenches.
one to hold the bolt and one to turn the nut.
turning the nut and not the bolt it will force the pully on
Old Apr 10, 2011 | 08:57 PM
Franklin2's Avatar
Franklin2
The end of the pump shaft should have threads up inside correct? If so, a threaded rod from the kit should thread up into the pump shaft, and there should be a nut that you use to press the pulley back on by turning the nut. The whole idea is not to put any pressure on the pump housing, just use the shaft itself to install the pulley.
Old Apr 11, 2011 | 04:09 AM
blucollar4xford
I thought so too, but the end of the shaft looks like a big Allen screw. Guess I never paid attention as to whether or not there were any threads in there or not. Oops! Well, hopefully this afternoon I have power steering again.
Old Apr 11, 2011 | 07:03 AM
fellro86's Avatar
fellro86
you have to look a little further in, the threads are in deeper. You can do it with a bolt, washer and nut, which is what the new ones come with. The puller/installer is typically a bit better, but the cheapy loaners don't always have the good installer bases.
Old Apr 23, 2011 | 09:13 PM
Marky48170's Avatar
Marky48170
65 f250, 67 f100, 76 f250
I have a question about pulleys, are they all the same size for the shaft and pulley? My 76 F250 w/360, I need to find a pump, pump bracket & pulley. I'm looking @ staying with a ford pump because I'm sticking with the hydro assist steering. Any help would be great.
Old Apr 23, 2011 | 09:49 PM
ctubutis's Avatar
ctubutis
Not sure what you're asking but I'm imagining the shaft diameter is the same across the board....
mxer0022
Sep 13, 2016 09:58 PM
Don Vito
Jul 1, 2016 12:49 PM
rpaxton939
Sep 8, 2014 03:31 AM
Pete Kildow
Large Truck
Sep 27, 2013 04:46 PM
jeff14346
17
Mar 23, 2013 05:42 PM
