Power window switch cover -'97 F350
Old Apr 10, 2011 | 07:26 PM
philvb's Avatar
philvb
I've attempted to find a replacement for my drivers side power window switch cover, with no luck. Does anyone know where I might be able to obtain a replacement? What I'm looking for is a replacement for the cracked cover shown below. Thanks!
Old Apr 10, 2011 | 08:16 PM
Encho's Avatar
Encho
The Southernmost Mod
Try LMC, a junkyard is the other option. Oh, and welcome to FTE!
Old Apr 11, 2011 | 06:42 PM
philvb's Avatar
philvb
Thanks for the tip and the welcome to the club
Old Apr 11, 2011 | 07:12 PM
Diesel_Brad's Avatar
Diesel_Brad
Junk yard, ebay or craigs list are your only options. No one reproduces a crewcab master window trim panel.
Old Apr 11, 2011 | 07:40 PM
Nevada Al's Avatar
Nevada Al
Mine looks the same way.. I've found two at the JY so far and they were broken too...
Old Apr 12, 2011 | 07:48 AM
Diesel_Brad
I collect them. I have 2 spares for each one of my crewcabs
Old Apr 12, 2011 | 07:10 PM
philvb's Avatar
philvb
I was about to remove the bezel to see if I could get a part number off it, but I am a little leery on doing just that since it could actually break in the process. If you have spares, any chance you could check to see if you can read a part number off it? It would help in my internet searches and contacts with junk yards, I assume.
Old Apr 12, 2011 | 09:07 PM
Nevada Al's Avatar
Nevada Al
Rub it in...
Old Apr 12, 2011 | 09:47 PM
L. Ward's Avatar
L. Ward
It is totally obsolete. LMC, etc do not have it either. Your best bet is (hopefully) finding one in a JY somewhere. I have given up finding one for my CC resto and will be mounting switches elsewhere to control the rear windows.
Old Apr 12, 2011 | 10:17 PM
CJM8515's Avatar
CJM8515
Real easy fix, fiberglass it, sand it down and paint it. Bit of work but it wont break again to easy.
Old Apr 13, 2011 | 04:28 AM
Diesel_Brad
A non power mirror one is # F4TS-14A335-AFW
A power mirror one is #F4TS-14A335-BFW
Old Apr 13, 2011 | 08:09 PM
philvb's Avatar
philvb
Thanks for the part number! Perhaps I will be able to find one either online or through contact with a JY.
In regard to the fiberglass option, I'm just not that knowledgeable in that area to pull it off. I did read a recent article in "Wired" magazine that covered 3D printing services using CAD/3D files. Once the object is drawn out in your CAD software, and then converted to a 3D image file, a number of different companies can then 3D print it in medium such as plastic. Sounds promising, now I just need to learn how to use a CAD program.
Oh well, my search for that part continues. Thanks for all the tips and info from you all, much appreciated!
Old Dec 9, 2018 | 10:24 PM
95crew's Avatar
95crew
Found this
I found an aftermarket one on ebay, and finally broke down and bought one. Link: https://www.ebay.com/itm/Window-Switch-Trim-Bezel-1995-1997-Ford-F-series-Crew-cab/132878515557/ I have put it off for too long, and figured $40 was worth it. It looks great and it's hefty. Should last a long while. Thank you all for saving my hide, more than a few times!
Old Mar 23, 2021 | 07:52 AM
Hqrse's Avatar
Hqrse
2nd Gear
Replacement bezel for 1997 Ford F350 Crew Cab
Has anyone purchased the 3D printed bezel ? If yes, how does it fit and look ? I've been trying to find a replacement for mine for a long time.
Thanks !
Old Oct 30, 2025 | 01:05 PM
Davepitts's Avatar
Davepitts
3rd Gear
3 D printed switch plate
Thanks !
They fit like crap, they're too short.And not wide enough. I have tried 5 different 3D printed switch. Blade covers for my 97 from 5 different 3D. Printers, they're slightly different, but none of them fit
