IWE Scare
Old Apr 10, 2011 | 02:58 PM
xjcamaro89's Avatar
xjcamaro89
IWE Scare
I was on my way home from work Friday and had the radio loud, but thought i felt it feel like the IWEs were trying to engage. So i turned the radio down and tried to get it to replicate but couldnt. So today i got the trusty vacuum guage out and started checking everything. Everything checked out fine but found a small leak.
When i replaced the check valves, i used a 3 way valve cause i couldnt find a straight through on at the parts store, so i just used a plug cap to plug off the third port on the valve. Last year i heard the IWEs and checked the one check valve and found that the plug cap had dry rotted and wasnt plugging, so i replaced it with a short chunk of hose with a screw in the one end. That fixed it. Well today i checked them again, and the second check valve behind the battery and, yep, the plug cap had dry rotted on that one and was leaking, so i fixed that one the same way i fixed the other one and now good to go. Whew! I really didnt want to pull stuff apart again.
Old Apr 10, 2011 | 03:12 PM
xjcamaro89's Avatar
xjcamaro89
Actually, it just hit me as i was writing this that i didnt check the check valves when i had them out, so i just now ran out and pulled them off again, and low and behold the check valve that had the leaky cap plug was shot, good thing i had another one sitting on my shelf. Now i should be good to go! hahaha!
Old Apr 11, 2011 | 04:52 AM
60DRB's Avatar
60DRB
That'll teach you to leave old "three ways" on! Good catch. My truck's been fine since you helped me fix it a year ago. I'll never forget the first time I heard that left front buzzing...I thought the tranny had blown or something!
Old Apr 11, 2011 | 06:44 AM
xjcamaro89's Avatar
xjcamaro89
I cant find straight through check valves at the parts stores around me. Plus i really didnt think that the plug caps would dry rott out like that so fast. Oh well
Old Apr 12, 2011 | 06:12 AM
60DRB's Avatar
60DRB
It is kind of wierd, the plain straight through check valves are often not on the rack. I could only find one when I started my trouble shooting and repair. I seldom see them in stock. I didn't use the one I got, but put it in the glove box...
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
krazybones
2009 - 2014 F150
23
Mar 4, 2015 08:24 PM
ChrisCarter
2004 - 2008 F150
Mar 12, 2012 07:12 AM
gcozmo
2004 - 2008 F150
Mar 21, 2011 06:29 AM
fordman19762003
2004 - 2008 F150
Mar 5, 2008 05:04 PM
