Sponsored by: Real Truck
Ignition Problems
Old Apr 9, 2011 | 01:19 PM
ALLMPL's Avatar
ALLMPL
Ignition Problems
Okay. Here it goes. Its very simple, when i turn the ignition, nothing, not a sound, does not turn over, nothing. When I start it in my driveway first thing, its starts up right away. Ill drive around doing errands and come out and try to start it and nothing. Ill wait awhile, sometimes about an hour, then it will start again. I replaced the starter, solenoid, and the ignition switch. Any suggestions?
99' Ford F-350 7.3 Diesel
Old Apr 9, 2011 | 06:31 PM
BBoy's Avatar
BBoy
is your truck auto or manual? check for bad grounds and if manual clutch switch
Old Apr 9, 2011 | 06:40 PM
ALLMPL's Avatar
ALLMPL
Automatic trans.
Old Apr 9, 2011 | 10:53 PM
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
Try to move your gear lever while you turn the ignition ,there's sensor in your steering column and it might need adjustment .
Old Apr 10, 2011 | 10:49 AM
FireMe's Avatar
FireMe
There is no sensor in the column. The trans range sensor is located on the transmission where the cable hooks up.
ChrisMelton78
Jun 20, 2014 03:01 PM
broncoholic
Nov 8, 2013 07:04 AM
WuTang
1978 - 1996 Big Bronco
Aug 8, 2011 07:30 PM
Malorkis
Sep 12, 2010 08:37 PM
swaybar
15
Jun 26, 2009 01:28 PM
