column shift lever problem- anyone have this problem?
Old Sep 10, 2008 | 07:31 PM
swaybar's Avatar
swaybar
recently when i go to start my truck it does nothing, have electric but no engine at all. when the ignitions turned half way i'll take the shift lever out of park then put it back in park real firm and the truck starts right up. i'm thinkin its got to do with the shift lever not recognizing its in park to start up. i'm not really familiar with this area and have never had this happen on any other truck, whatdayathink?
Old Sep 10, 2008 | 09:02 PM
F350-6's Avatar
F350-6
There's a couple of screws that hold the lever to the column (torx fitting I believe). Take a peek under there and see if they just need to be tightened up. Until you get to that, you might try just starting it in neutral so you don't break something else jamming it back into park.
Old Sep 10, 2008 | 09:19 PM
PaysonPSD's Avatar
PaysonPSD
Here's a PDF that will be of some help:
File Type: pdf
Old Sep 11, 2008 | 06:07 PM
swaybar's Avatar
swaybar
thanks for the input, i using my car for now just to be safe. don't want to get stuck anywhere. i'll be getting into it saturday morning.
Old Sep 11, 2008 | 08:50 PM
trike1946's Avatar
trike1946
This happened to me too. What you have to watch out for:
You may not be in Park and the truck rolls when you get out.
You have to start in neutral.
You may not be in drive, it may be drive 2.
Reverse may not be where you think it is, and it won't go in when you really need it to.
Otherwise it is no problem.
Old Sep 12, 2008 | 09:23 PM
swaybar's Avatar
swaybar
[quote=trike1946;6538632]This happened to me too. What you have to watch out for:
what was it?
Old Sep 12, 2008 | 10:04 PM
UP_There's Avatar
UP_There
Long before I discovered FTE.....I had this same problem, I brought the truck to a tranny shop, and the guy fixed it in less then 5 minutes. What Chris said is what fixed mine.....just an adjustment under the collumn is all it took. The guy didn't even charge me!
Old Sep 12, 2008 | 11:57 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Under the dash fuse cover right below the steering wheel there is a barrel nut you can turn that will center the gear indicator. I think you chock the wheels, put it in neutral and then turn it a little at a time until the gear selector is centered on N. That's what worked on mine anyways.
Old Sep 13, 2008 | 05:23 AM
trike1946's Avatar
trike1946
swaybar, I ended up replacing the shift lever.
Old Sep 13, 2008 | 06:59 PM
swaybar's Avatar
swaybar
i found the barrel nut on the shift lever cable and was able to center the arrow indicator on the dash to the center of each gear (drive, reverse,etc), easy enough. then when i went to start it, it cranked for 1/2 second then wouldn't start, put it in neutral and it started. did this a few times with the same result. Now i've been way overdue for an oilchange and thank god for FTE, cause i've found out on here that the engines very sensitive to its oil and said "maybe". well changed the oil and i've stared and stopped it 50 times today with no problems. starts everytime smooth, crisp and fast. so between fixing the shift lever cable and the oil change its turned out to be a good day.
Old Sep 13, 2008 | 07:43 PM
Powerstrokedlariat
Great, hopefully you have this problem licked. Think how much money you just saved yourself cause of this place.
Old Sep 13, 2008 | 09:05 PM
zack7.3's Avatar
zack7.3
I always like days like that. When it feels like you accomplished something.
Old Jun 26, 2009 | 04:33 AM
wahusker's Avatar
wahusker
Stung again before reading FTE! I was getting fuel today and couldnt get my truck into park. long story short I was two blocks from my mechanic and stopped by, he said two hours labor at $60.00 per hour and I should be good to go! Seems like a problem I could have fixed!
Old Jun 26, 2009 | 07:21 AM
megawatt00's Avatar
megawatt00
That is 1 hour per screw! You could have fixed it yourself no problem at all.
Old Jun 26, 2009 | 01:17 PM
gtnwood's Avatar
gtnwood
2 hr's for 120.00.......I dont know, I've never paid for it myself but that sounds kinda cheap, hope his mech. is a hot chick
