Tailgate stuck
Old Apr 8, 2011 | 08:07 PM
jslaymon's Avatar
jslaymon
Tailgate stuck
I'm new to this truck (1994 f350) so I'm not sure how the meachnism works. The tailgate is stuck in the closed position. I removed the inside panel and see that the rods are moving when the handle is raised. I also took a pair of pliers and squeezed the mechanism together to ensure it was released as far as it would go. The tailgate still won't open. Any thoughts on how I can get this opened?....thanks
Old Apr 8, 2011 | 08:54 PM
skyfox10's Avatar
skyfox10
I'd hit all the moving parts that you can see with penetrating oil. Usually it seems that they end up sticking open and they wont latch, not closed like you have. If you see both rods moving, the the problem may be where the tailgate latches to the bed, which is gonna be hard to get to.
Can you confirm if both sides are sticking or just one side?
Old Apr 8, 2011 | 09:55 PM
F3fitty's Avatar
F3fitty
Not. Sure on this one. I'll open mine up tomorrow and look at it.
Old Apr 10, 2011 | 10:29 AM
jslaymon's Avatar
jslaymon
It seems like both sides are stuck. There's no real play on either side. I'll try to get some penetrating oil sprayed inside. A picture of the latch where it catches would help......thanks
Old Apr 10, 2011 | 03:00 PM
91chevywt's Avatar
91chevywt
You might want to try looking at the hinge at the bottom, maybe lifting up on the gate, pushing, pulling while trying to open it. On mine, the one bushing on the hinge was totally gone, making the tailgate really difficult to open. Had to jump up on the bumper and pull up on the handle pretty hard to get it to unlatch. I got a new bushing for it, and all is well.
Old Apr 13, 2011 | 07:29 PM
jslaymon's Avatar
jslaymon
Tried lifting while someone pulled on the handle, no luck.
Old Apr 13, 2011 | 07:45 PM
SideWinder4.9l's Avatar
SideWinder4.9l
A little bit of hot wrench will get it unstuck!
-Wes
Old Apr 13, 2011 | 07:55 PM
danger-ranger93's Avatar
danger-ranger93
Little bit of cutting in half and going to the junkyard is what I'd end up doin... But there are 3 trucks out there the same color as mine..
Azuretruck
Sep 5, 2016 09:16 PM
noeldner07
Aug 30, 2011 12:47 PM
EBrown
1983 - 2012 Ranger & B-Series
Dec 20, 2006 05:53 PM
saultman
Sep 25, 2006 05:40 PM
65limo
1978 - 1996 Big Bronco
May 8, 2002 03:19 AM
