1978 - 1996 Big Bronco
Tailgate window won't operate
Old Apr 22, 2002 | 11:41 PM
65limo's Avatar
65limo
Hi. I have an '89 Bronco with a problem I can't diagnose. I am not highly experienced in electrical problems, but generally can follow good instructions. Today with no warning my tailgate window stuck in the open position, and will not close. I checked the switch with a continuity tester, and it's fine. I also checked for power at the switch, and it's there. Fuse is fine. I've been meaning to replace the lock mechanism, which has been inoperable for about six months. I have bypassed it by the switch. Now nothing works. I'm not sure even how to get at the motor or lock mechanism with the glass inside the gate. Any suggestions? Thanks. 65limo
Old Apr 23, 2002 | 07:25 AM
emboyd's Avatar
emboyd
I had the same thing happen w/ my '84. Here's what you do:
Make sure the tailgate is closed completely. Usually, the driver's side won't close all the way, so go give it a good hard push to make sure it is all the way latched.
Let us know if that fixes it.
Thanks.
EB
Old Apr 23, 2002 | 10:07 AM
65limo's Avatar
65limo
Thanks for the suggestion. I had read a similar suggestion yesterday, but went out this morning and tried it again. I also oiled the latches. Everything closes tightly, and even with pressure applied against the tailgate, I can't get the glass to go up. I can't figure out how to get at the motor with the glass being down. Thanks for your suggestion, and I'll watch for any others. There is certainly a solution. 65limo
Old Apr 23, 2002 | 07:43 PM
muddogin400's Avatar
muddogin400
i had the same problem with my rear window and it was a combination of a dirty ground wire and an conection that went bad. test the volts on both ends of each conection to see if yea got the same peoblem as i did. now the way i found out how to work on it with the tailgate down adn the window out is by first letting the tailgate down then pushing the latchs closed(the little things that clip around the stud) and turning the key under it shoudl move the glass. but be careful and hold on to teh glass as it goes out b/c it is quite heavy
Old Apr 24, 2002 | 02:28 AM
65limo's Avatar
65limo
Good suggestions. I've tried all of these things, but still can't get the window to budge. My wife wants her car back in the garage, and I'm not putting my other two out. So, I'll take the Bronco to a pro and get it fixed correctly. Thanks for the help!:-X11
Old Apr 30, 2002 | 07:07 PM
krs's Avatar
krs
I have an '87 that has chronic tailgate glass problems.
Some suggestions:
1.)Your regulator roller (it's actually a sqaure plastic piece) that rides in the channel has overrun the channel and jammed. It takes two to fix this: one to carefully hold the roller in its proper orientation to the channel, and the other to just tap the switch to make it go up/down to get the roller back in line. Watch those fingers!
2.)There is a safety override switch located (as you are inside facing the tailgate) to the mid to lower right inside the tailgate. My opened up and the glass would neither go up or down. So, I reached in there, pulled the switch out as far as it would go, cut the wires to the switch, and spliced the two wires in the wiring harness together. If you do this, you'll have no safety override, and the glass will go up or down whether the gate is closed or open.
3.)The glass is jammed in the channel. WD40 is very messy but a good lubricant to get it released.
Old May 1, 2002 | 01:23 AM
65limo's Avatar
65limo
Hey!!! It worked. I tried suggestion #2. It's only the latch on the driver's side that is linked and I oiled that latch very well, but still couldn't get the window to operate. I closed the latch manually and operated the window into the up position and had the window propped up because of the weight. Then I found the wires you mentioned, clipped the two which were both labeled "Y" and spliced them together to bypass the safety override. And it worked!!!! What a job to get at it, but it was surely a lot cheaper to do it at home than to take it to a body or electrical shop. Thanks very much for the suggestion.
Old May 8, 2002 | 12:45 AM
65limo's Avatar
65limo
More news on the tailgate window that might help others. After bypassing the safety switch, the window started working intermittently. I couldn't figure it out. The wires I spliced together were soldered and well taped. The glass quite operating again when I would close the tailgate. My nephew just finished advanced mechanic school, and brought over a readable wiring diagram. We traced the problem back to the wiring harness that comes out of the body and into the tailgate. Sure enough -- there was one wire broken and one mostly severed. I cleaned them up, soldered the ends together, taped it all up, and now everything works like a clock -- even the keyed switch. So, for those of you who have had problems like this, you might try taking the black coating off of the wiring harness and check the condition of the wires. There's still nothing like a real Bronco!
Thanks to all who help in this forum, and God bless those who serve!
Old May 8, 2002 | 03:19 AM
whitebenz's Avatar
whitebenz
Apocalypse
Sep 14, 2020 03:51 PM
thewheelman
Aug 9, 2016 06:38 AM
bkvanbek
Jul 14, 2016 08:48 PM
Moe Craig
Mar 13, 2016 10:43 AM
vogey
Oct 11, 2005 06:50 PM
