Failed EGR valve?
Apr 7, 2011 | 03:40 PM
Failed EGR valve?
I was trying to figure out my smoke problem...
Well I unplug the EGR valve and all of it goes away.
Plugged in and it all comes back?
I cleaned it thoroughly and didnt change...?
Did it fail electronically?
Apr 7, 2011 | 06:59 PM
I thought you deleted your egr cooler no exhaust flow how could it smoke.
Apr 7, 2011 | 07:42 PM
Well when my welded cooler failed. I replaced it with a regular cooler again. So my egr system is working again
Apr 7, 2011 | 08:05 PM
You installed the bulletproof EGR cooler didnt you?
Apr 7, 2011 | 08:12 PM
Yea what did you replace it with
Apr 8, 2011 | 12:07 AM
Quote:
Originally Posted by
2006powerstroke90
what failed on your welded cooler?
Apr 8, 2011 | 07:38 AM
Bulletproof...
Would that smoke mean something if the egr is plugged in or unplugged?
And I am not sure if the welds failed or what, but when I replaced it my problems went away.
Apr 8, 2011 | 08:35 AM
just get you a new tuner or use the old one and leave the truck stock and turn off the egr valve. or if you get a new tuner since the other one is "bad" try it to make sure it was the other tuner that was causing your problems
Apr 8, 2011 | 11:06 AM
I have it unplugged right now, is this going to harm anything?
Apr 8, 2011 | 11:20 AM
your fan might not work properly. like i said plug it back in and use the sct to turn it off and you dont have to worry about it. its the same thing as unplugged but your fan will work properly
Apr 8, 2011 | 01:31 PM
have you driven it hard since you changed the cooler?.when mine went out it took some hard driving to get it to clear out.took a month to burn the oil out of my exhaust when my turbo cut loose.btw,what color is the smoke?.
Apr 8, 2011 | 01:39 PM
ivory-tower
Jan 17, 2013 08:00 AM
B846B
Nevada Chapter
May 10, 2011 07:19 PM
UGA33
Aug 1, 2010 10:05 AM
mremail1964
May 31, 2006 10:03 PM
tmcalavy
Jan 24, 2000 11:28 AM
06 ,
49 ,
60l ,
caused ,
diesel ,
egr ,
f350 ,
failed ,
failing ,
ford ,
high ,
idle ,
pipe ,
stright ,
system ,
truck ,
valve
