icp question??
Old Apr 6, 2011 | 04:11 PM
bcaughhorn's Avatar
bcaughhorn
icp question??
i was just checking out some stuff on my truck today. i pulled the plug on the icp sensor. it had oil on the plug. im thinking i remember reading if there was oil on it that it is bad... is this correct? if so is it safe to buy this from advance?
if the icp is bad then my edge ezf probably isnt bad rite? it would have been the icp all along???? maybe....
Old Apr 6, 2011 | 04:15 PM
clintbonnie's Avatar
clintbonnie
It is bad.. get one from www.PartsGuyEd.com one of our sponsors .. great prices on OEM ford stuff..
Old Apr 6, 2011 | 04:25 PM
bcaughhorn's Avatar
bcaughhorn
would that be the pressure sensor on the fuel system???
Old Apr 6, 2011 | 04:26 PM
clintbonnie
It a sensor for the high pressure oil system for your injectors..
Old Apr 6, 2011 | 04:27 PM
bcaughhorn's Avatar
bcaughhorn
ok. thanks
Old Apr 6, 2011 | 04:29 PM
clintbonnie
Originally Posted by bcaughhorn
ok. thanks
Here is link for more info..
http://www.aeswave.com/images/Produc...20sample73.pdf
Old Apr 6, 2011 | 05:00 PM
new2diesel's Avatar
new2diesel
Almost sound like the same q I asked a couple days ago. I ordered one from Clay,
waiting for it to arrive. Will see if it makes a diff. in how my truck starts.
new2diesel's Avatar
new2diesel
Old Apr 6, 2011 | 05:04 PM
bcaughhorn's Avatar
bcaughhorn
Ok. I guess I missed yours then. Let me know how it works. Mine starts good. Atleast I think so
Old Apr 6, 2011 | 08:22 PM
new2diesel's Avatar
new2diesel
mine starts good but there's a sweet spot. if I wait too long or not
long enough it has to crank a little longer.
Old Apr 6, 2011 | 08:25 PM
bcaughhorn's Avatar
bcaughhorn
mine does that too. sometimes faster than other times
Old Apr 6, 2011 | 08:29 PM
PaysonPSD's Avatar
PaysonPSD
If oil is leaking from around the sensor the o-ring is bad. If the oil is leaking through the sensor the sensor is bad. If you remove the ICP connector and start the engine and see oil welling up in the sensor it is leaking throuh it. That sensor is subjected to 500 PSI of oil pressure at idle and the pressure only goes up from there.
Old Apr 6, 2011 | 08:36 PM
bcaughhorn's Avatar
bcaughhorn
it wasnt around the outside. it was on the plug when i pulled it out. i didnt start it while it was unplugged. i saw the oil and wiped it off and pluged it back in..
would the bad sensor cause my edge ezf not to work properly ?
Old Apr 6, 2011 | 09:28 PM
PaysonPSD's Avatar
PaysonPSD
If the ICP leaks it needs to be replaced.
How does the EZF connect?
Old Apr 7, 2011 | 04:51 AM
bcaughhorn's Avatar
bcaughhorn
the edge connects to the icp
