Bronco II Ford Bronco II
Remedial EFI help
Old Apr 5, 2011 | 03:13 PM
Old93junk's Avatar
Old93junk
Remedial EFI help
I have a 87 B2 2.9 5sp I am trying to resurrect from the dead. The body is beautiful, but it sat for unknown reasons for 3 years in the blackberries until I came along. The wiring is a hacked mess but it seems to be limited to the lighting circuit and I seem to have it sorted out. Finally got to get it to turn over great with the starter, has HOT spark, but is getting NO fuel.......pump in tank does not run, no fuel/press. in fuel rail, no power at inertia switch, all fuses are good....The entire fuel system seems dead.
I am NOT a EFI guy........I know and prefer carbs, please help a EFI idiot, I have no idea where to start electrically, and do not want to burn this thing to the ground trying. No schematics I can find even hint at power to the fuel pump, I have never had EFI on any other rigs give me trouble, so no experience.
Thanks in advance.
Old Apr 5, 2011 | 07:34 PM
monckywrench's Avatar
monckywrench
You will have to make friends with the EFI schematics and search this and the rangerstation forums. There is plenty of info in both places because relay and pump problems are common.
What I do it to carefully pop off the covers of the appropriate EEC power and fuel pump relays with a small flat screwdriver so I can observe if they operate.
You can then switch them manually by pressing the contacts together with a screwdriver handle or other hunk of plastic.
I collect extra relays for troubleshooting when I'm in salvage yards.
Old Apr 5, 2011 | 07:45 PM
Old93junk's Avatar
Old93junk
I just replaced the fuel pump relay............no luck
I had a hard time telling which is which, ones green, the other brown? The contacts are very similar.......will the EEC relay also result in dead fuel system?
Not sure how to tell if they are operating at all.
Old Apr 5, 2011 | 08:40 PM
monckywrench
Yes. The EEC relay must function first.
Remove the cover from the relay and it will become clear when you see the contacts. Relays are merely solenoid-operated switches.
Old Apr 5, 2011 | 08:48 PM
Old93junk's Avatar
Old93junk
Well, the relays are cheap, so I will try the EEC relay next.
The hacked wiring was all in the parking light/headlight circuit after some PO shorted and melted the front parking light wires, so I am confident it has nothing to do with this.
I feel I am 12 volts in the right place, away from getting this thing running.........
Gives me anymore grief, I will start looking for a good carbed 2.8, or a 302 swap, too much effort to get a 2.9 running.......grrrrrr
Old Apr 5, 2011 | 09:12 PM
monckywrench
If you are going for a fresh relay anyway, open the old ones and use them as indicators.
What to the relays actually do when exposed? Move? Not move? What happens when you hold the EEC relay down?
You can also bypass the CONTROL portion of the relay by using a switch wired to a couple of blade connectors to jump the POWER pins.
Replacement won't tell you what they are DOING if it still doesn't run.
Once you get the hang of it you will be able to troubleshoot a variety of Fords.
Old Apr 5, 2011 | 09:19 PM
Old93junk's Avatar
Old93junk
Well the one I replaced was swimming in water and rust!........NO movement possible, if the EEC relay looks the same, this may be it.
The protective cover that Ford puts over the relays where they are mounted is MIA, and the relays are laying with the bottoms exposed on the fender liner, under a layer of wet pine needles.
Old Apr 6, 2011 | 09:05 AM
monckywrench
Zip tie them out of the puddle zone and inspect/clean the socket contacts. The old lithium spray grease trick is a good idea.
Old Apr 6, 2011 | 10:00 AM
Old93junk's Avatar
Old93junk
As soon as it quits raining (good luck) I will change the EEC relay out.
Jeez, you mean rusted solid hunks of crud are not operating relays?
Old Apr 6, 2011 | 06:24 PM
Old93junk's Avatar
Old93junk
Both relays replaced...........no effect, still deader than dead.
Anybody want to buy a nice (but dead) B2?
Old Apr 6, 2011 | 06:57 PM
monckywrench
https://www.ford-trucks.com/forums/3...-problems.html
Super High Output
Old Apr 6, 2011 | 08:32 PM
Old93junk's Avatar
Old93junk
Thank you!............
Already got my test light and multi meter ready, along with test leads.
There's a virtual six pack headed your way if it kicks over.
Old Apr 6, 2011 | 08:52 PM
monckywrench
If you want to here it make fuel pump noises, jump the EEC and the fuel relay power lines. Fuel pump noises are reassuring, though when they are that old it doesn't guarantee long-term fuel delivery!
If you want to know when each gets signal, put the test light across the contacts that drive the relay coil.
Looking at the bright side, by the time you are done you'll be comfortable with troubleshooting.
Check the inertia switch too. I'm from the school of "jumper everything that's a switch" then figure out the rest after the fuel pump runs.
Old Apr 6, 2011 | 08:59 PM
Old93junk's Avatar
Old93junk
Unfortunately, this rig sits outside.........The wife's rig gets the garage, so as soon as the weather clears I will be back on it.
Any danger of smoking the EEC with all this jumpering?
One lead on the inertia switch did look like it had gotten hot.
Old Apr 6, 2011 | 09:23 PM
monckywrench
If you see a lead that looks crispy, then I'd try to find out why. The fuses "should" protect things but stuff happens. The lead may just be old. These trucks are ancient now and can have discolored wiring.
Of course, if I got the vehicle for cheap or free I'd just jumper it on the theory it won't let the magic smoke out unless there's a problem to begin with!
See if this helps:
Inertia Switch How To - Ford Explorer Ranger Enthusiasts "Serious Explorations"®
