4.9 block compatability
Old Nov 23, 2002 | 09:10 PM
tdc's Avatar
tdc
Post 4.9 block compatability
[updated:LAST EDITED ON 23-Nov-02 AT 10:18 PM (EST)]Was given a 1987 F-150 w/4.9 L-6. Told computer is out and needs timing gears. Unsure of condition of engine. Can get reliable 4.9 from uncle out of 84. I know that the heads are different. Are the blocks the same?
Old Nov 23, 2002 | 09:17 PM
chuckman's Avatar
chuckman
all motors from 87-95 are the same, and utilize the same parts. pre-87 trucks had carbs and different heads, intake, and exhaust, ant the 96 had a different computer setup, but mechanically was the same.
Old Nov 23, 2002 | 09:21 PM
tdc's Avatar
tdc
Thanx for the reply, i accidentally put 94 , meant 84. trying to put truck on road as inexpensively as possible. any tip would be great.
Old Nov 23, 2002 | 09:25 PM
Pastmaster's Avatar
Pastmaster
The 84 300 would have a engine block fuel pump. I'm not sure if you can buy an bolt-on cover for it or not.
Otherwise it should work fine.
Use your Serpentine bolt system
Old Nov 23, 2002 | 09:38 PM
tdc's Avatar
tdc
thanx for reply. have a "ford guru" friend near uncle w/engine. will consult with him about fuel pump difference. I thought the basic L-6 design hadn't changed , and this seemed like a good place to ask.:-X12
Old Nov 24, 2002 | 12:58 AM
ecarter50's Avatar
ecarter50
A smallblock chevy fuel pump cover will fit.
Old Nov 26, 2002 | 11:05 AM
honney's Avatar
honney
Old Dec 23, 2002 | 02:48 AM
FordTruckMan76's Avatar
FordTruckMan76
First check to see if the block has a provision for a knock sensor, look on the 87 motor and then on the 84 motor, other than that yes the blocks are the same
Old Dec 23, 2002 | 07:48 AM
steve83's Avatar
steve83
The old block doesn't have the KS, but you can drill & tap the hole for it.
Old Dec 23, 2002 | 01:00 PM
Ford_Six's Avatar
Ford_Six
Actually, it's a big block chebbie fuel pump cover. The small block plate uses four bolts, while the big block one uses two.
Jared
Old Dec 23, 2002 | 05:13 PM
EPNCSU2006's Avatar
EPNCSU2006
[updated:LAST EDITED ON 23-Dec-02 AT 06:14 PM (EST)]Small chevy's have 2 bolts on the fuel pump or the block off plate, not 4. I know, my friend's race car is a small block chevy.
