Could really use some bodywork help.
Old Apr 6, 2011 | 06:10 AM
iwanaflattie's Avatar
iwanaflattie
Maybe kevin could fab you some I dont know if he is still around but his website still there i think.....
RRust repair time! I am not doing any body work at this time just rust repair and metal finish with a worn out paint look to try and match the rest of the truck. I do not want the repairs to stand out but more look like they were done years ago. I need to play with my greens a bit more but you get the idea.
Kevin
LFD Inc.
http://i16.photobucket.com/albums/b2...n/DSC04632.jpg
I wheeled up a patch panel to fit.
http://i16.photobucket.com/albums/b2...n/DSC04633.jpg
It is not a lot of curve but it sure makes a big difference in how much filler you will use later.
http://i16.photobucket.com/albums/b2...n/DSC04634.jpg
http://i16.photobucket.com/albums/b2...n/DSC04636.jpg
http://i16.photobucket.com/albums/b2...n/DSC04646.jpg
Captured nut plates for easy mounting!
http://i16.photobucket.com/albums/b2...n/DSC04630.jpg
Time for the paint treatment on the drivers fender.
http://i16.photobucket.com/albums/b2...n/DSC04631.jpg
__________________
www.lewisfrabricationdesign.com
Old Apr 6, 2011 | 06:26 AM
iwanaflattie
Now for a little step by step for the passenger side fender. This one is by far the worst front fender but still easy to fix if you take it one step at a time.
Kevin
LFD Inc.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Lets start with the front repair. First make templates for reference.
[IMG][/IMG]
[IMG][/IMG]
Checking the fit on the fender for curve and over all shape.
[IMG][/IMG]
Then I check the fit to the lower front section.
[IMG][/IMG]
This is as far as I got today and I will finish it up in the morning. I just used my mig to tack it but will grind those down and Tig the entire weld so I can hammer finish it as best as I can. I will finish the last section of the wheel opening once it is bolted together and I can blend the shape so it flows correctly.
[IMG][/IMG]
__________________
Old Apr 6, 2011 | 06:33 AM
xcrunner2616's Avatar
xcrunner2616
hey guys thanks for all the comments and help. i have never done any body work before but my father in law does it quite frequently. i wont let him do anything on my truck other than turn a bolt though. but it sure is nice to know that he will be around if i need it. not to mention you guys.
one thing about me is that i am not afraid to try anything.
propellerhead
15
Apr 25, 2017 12:28 PM
Raleigh1
1978 - 1996 Big Bronco
682
Mar 18, 2016 01:29 PM
MOOSE_MACHINE
Testing.....
Mar 18, 2014 07:03 PM
postoak99
1997 - 2003 F150
Mar 5, 2011 11:05 AM
