Shes Running..but too hot with CU511
Hey guys..I got the 300+ HP SBC running great but cant keep er cool with the CU511 Rad...the Thermostat opens ok...and when I start er up when warm the temp drops good so I am thinking the water pump is doing its job too...the 16" electric puller fan cant seem to keep up.It does take 5-10 mins for it to get too warm..is it possible that its too much engine for the CU511? maybe I need 3 or 4 passes? any opinions are very welcome..Thank you
on
on
Thermostats restrict the flow of coolant to ensure it stays in the radiator long enough to cool it. Depending on the radiator and/or engine combination a thermostat may restrict the flow too much...
the radiator guy bought an el cheapo stat and cut the guts out, leaving only the hat, and the overheat problem went away.. (course it cooled off too much while driving, so I installed a real 195 degree cheapo stat later)
see the pics here https://www.ford-trucks.com/forums/8...ml#post7928579
the right/bottom is the can (problem) type, the center/middle is the one I use now, and the one we cut the guts out of.
so, the water flowed too slow, and collected more engine heat, but couldn't dissipate the heat, so came back a few degrees hotter, and picked up more heat, and... repeat.. slowly climbing til pop!..
Sam
Thanx guys... I looked on the spectra premium site and it said 2 passes or rows is that a 2 core? I wasnt aware that it was a three core as its way thin...anyways ..if it works on your 355 it should easily cool mine...I changed the thermostat and saw a difference it stayed at 185 for 10 mins with the electric fan on...I am pretty sure my thermo switch for the fan is not working...earlier it spiked over 210 and I could barely cool it down..I am hoping it was the T stat
nah..
all I was suggesting is to test and see what the behavior is. I spent months changing everything else, cause it COULDN'T be the problem, as it opened and closed at the defined temp just fine, and was new...
good part, bad application..
if you want, buy a cheap thermostat and cut out the temp sensing part, leaving just the hat, and put that in instead. that will give you max flow.
as your symptoms sound exactly like mine, slowly escalating temps.. I'm betting this could be the same problem.. particularly on a newly rebuilt engine.
sam
sam
test..
Sam
