Updated fuel spring part #
Old Apr 5, 2011 | 06:08 PM
BLADE35's Avatar
BLADE35
Originally Posted by 429poweredf350
This is the kit I used. I paid $52 at Tasca.
this was the kit i got to I just wanted the extra stuff to ya never know when youl need it I did pay 76.65 in aug 16,2010
Old Apr 5, 2011 | 06:45 PM
1bad04's Avatar
1bad04
I dont mean to hi-jack, but has anyone else experiencing slower turbo spooling after the blue spring upgrade like I am?
Old Apr 5, 2011 | 07:48 PM
2006powerstroke90's Avatar
2006powerstroke90
Whats up with the bb mod?
Does it really work?
I called the ford dealer ship today. He said it would cost me 80$ and he wasn't sure if it was the blue spring or not.
Old Apr 5, 2011 | 07:56 PM
BLADE35's Avatar
BLADE35
that bb is from your kids re ryder bb gun some do go with a hardened bearing
it just throws the spring a bit further
I just didnt like the fact it could get lost easy during assembly or disassembly
i went with the 80.00nkit
but they did have just the spring high volume ford dealer
Old Apr 5, 2011 | 08:10 PM
wulfman's Avatar
wulfman
Boys PartsGuyEd like 52 plus shipping. And i seem to notice quicker throttle response, not in the turbo but just seem to run better. jmo
Old Apr 5, 2011 | 08:12 PM
2006powerstroke90
I will try to contact him.
But just temporary would the bb work?
Where does it go? Front or the back of the spring?
Old Apr 5, 2011 | 08:39 PM
wulfman's Avatar
wulfman
I have no idea but its in the tech folder
Old Apr 5, 2011 | 08:45 PM
wulfman's Avatar
wulfman
Just checked tech folder not there, i have no idea but i have read about it just can't remember where
Old Apr 5, 2011 | 09:44 PM
BLADE35's Avatar
BLADE35
bb goes in the cover once you open the cover you will see where the spring seats on outer cover put bb there then spring
it just makes the spring push harder on the plunger thats opens the return line
once you get cover off you will see
I just did this to prevent premature injector failure with the stock deadend fuel rail it fires multiple injectors on the same side one after the other leaving fuel press low
Old Apr 5, 2011 | 10:54 PM
waddell_cb's Avatar
waddell_cb
To clarify, I should have only put the base number 9T517. I agree with you about them constantly changing part numbers and that is why I refer to the base number when I talk to Tousley or Ed about parts. I will plug in the entire number into their online searches though to see what it pulls up. It really does help to have the entire updated number though.
I also called a local dealer parts store in my area and asked about the 9C165 kit and weather or not it contained the spring. They pulled it off the shelf and said it did not have a spring and that it was just an o-ring kit (see fordparts.com for exploded diagram). I asked them if they had any other kits or numbers for just the spring and they said 9T517 is the only one they have.
1854267C94 and 1843065C98 are two International part #s that I see posted. I am not sure one or the other, but some guys are recently posting that the item is "restricted".
I may try these numbers this week with my local Int. parts guy and see what happens. I may just end up with my BB for the long haul.
Old Apr 6, 2011 | 04:22 PM
smokersteve's Avatar
smokersteve
The bb mod worked when I did it, then a few months later I got the updated spring.
Old Apr 6, 2011 | 05:01 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Just a warning using the BB Mod. You need to have a fuel pressure gauge when doing this mod. Some have reported their fuel pressure went too high doing this. For what ever reason.
There have been numerous reports that the BB mod works well, and is pretty darn cheap.
Just be careful.
sawmaned
General Diesel Discussion
Sep 9, 2015 08:04 PM
B-2
20
Nov 5, 2013 10:37 PM
dmanlyr
Large Truck
Apr 3, 2013 05:58 PM
rmr1r
Jan 27, 2013 09:59 PM
Big Ruth
Jan 25, 2010 11:48 AM
