Sponsored by: Real Truck
Intermittent wiper problem 2005 SD
Old Apr 4, 2011 | 01:18 PM
paulquenzler's Avatar
paulquenzler
Angry Intermittent wiper problem 2005 SD
I have an F-350 SD 2005 6.0 diesel DRW.
On our last camping trip, hauling a 5th wheel, suddenly the wipers came on in slow intermittent mode.
I took apart the multifunction switch, cleaned it and reinstalled, no joy. All other aspects of the MF switch work fine, I.e. Hi lo beams, turns and flashers.
I have been reading some other threads that talk about the relationship between the switch, the GEM, and the motor, along with the several relays that are involved. I don't have a wiring diagram.
I disconnected the multifunction switch and the wipers continue to operate in slow intermittent mode with the ignition on.
In looking at the switch, I did some continuity checks and found that if I check the black wire (assuming that is common) I get various different connections between the black and other wires for different switch positions, so I am not convinced the problem is the switch.
Does anyone have a good diagnostic procedure to determine the problem.
Also, for my truck, where are the relay's and the GEM?
Thanks
phoneman91
64
Feb 2, 2025 05:40 PM
Phanman43
Mar 4, 2014 07:08 PM
Devious Delight
13
Dec 9, 2013 08:01 AM
Blueman2
Nov 26, 2011 12:17 PM
boz
1983 - 2012 Ranger & B-Series
Jan 12, 2004 10:19 AM
