Need help, I've got a gremlin.
Old Dec 1, 2013 | 06:04 PM
Devious Delight's Avatar
Devious Delight
1997 expedition.
Problems:
speedo and tach don't work (I have 2 clusters, same problem on both)
wipers don't work.
Replaced:
GEM with known good module.
wiper stalk (multifunction switch) (as of 12/8)
I'm working on the wipers first
Tested the power at the wiper motor. No power.
1.5 ohms of resistance on the ground.
I have checked all fuses (both under the hood and under the dash).
I have moved all of the relays as well, to no avail.
Any other thoughts, or ideas?
Thanks guys
Old Dec 1, 2013 | 06:17 PM
ashleyroachclip's Avatar
ashleyroachclip
I believe you can test the stalk, just as you have done your other tests.
Do you have a wiring diagram , so you know which color wires are which?
Old Dec 1, 2013 | 06:19 PM
Devious Delight
Do not. Wiring isn't my strongest suit. But I'd like to think I'm competent. Where can I find one?
Old Dec 1, 2013 | 08:13 PM
Devious Delight
weird...
I hooked up the switch for the lights, since I have to drive it tomorrow, and all my gauges except the speedo work again.
Cool! I've got a half tank of gas!
Now, to test that switch tomorrow.
Old Dec 1, 2013 | 08:32 PM
alloro's Avatar
alloro
For the front wiper, double check fuse #11 in the interior fuse box under the dash. I've also attached a PDF of the wiper wiring diagram.
File Type: pdf
Old Dec 1, 2013 | 09:52 PM
Devious Delight
From what I'm looking at, assuming that #11 is good, it has to be the switch, right?
Old Dec 1, 2013 | 10:16 PM
alloro's Avatar
alloro
No, it could be a relay, a bad connector, or a broken wire, just as easily.
Old Dec 8, 2013 | 06:17 PM
Devious Delight
gargh. Found a new motorcraft wiper stalk for $23. So I installed that.
No dice. Triple checked all the fuses. gah. Frustration.
Old Dec 8, 2013 | 06:39 PM
ashleyroachclip
Is there a wiper relay, I am guessing you have delay wipers.
the relays are all the same , will interchange in the fuse panel.
swap a know good one for the wipers.
Old Dec 8, 2013 | 07:12 PM
alloro's Avatar
alloro
In his first post he said he swapped the relays around and I'm guess it didn't help.
Old Dec 8, 2013 | 07:22 PM
Devious Delight
Correct.
Fuses are good, relays are good, wiperstalk is new, and GEM is a used known good replacement.
No power at the wiper motor.
Old Dec 8, 2013 | 07:28 PM
ashleyroachclip
The older fords had trouble with the ignition switch, not the tumbler.
as the switch started separating , some circuits would not work.
worth a check .
Old Dec 8, 2013 | 10:41 PM
alloro's Avatar
alloro
worth a check .
If it were the ignition switch, then other things like the radio, door remotes, and the rear wiper system would also not work. They all share the same accessory circuit running through the switch as the front wiper system.
Old Dec 9, 2013 | 08:01 AM
Devious Delight
I thought that would be the case. Thanks for confirming my thought alloro.
Kenny91_f250
Feb 4, 2018 04:57 PM
devino246
May 23, 2013 11:23 AM
BlueOval390
Dec 6, 2008 06:01 PM
64F250
Feb 27, 2007 07:35 PM
randehle
Jun 26, 2003 10:12 AM
