Sponsored by: Real Truck
wont start
Old Apr 4, 2011 | 12:18 PM
greentree ford's Avatar
greentree ford
wont start
I put two new batteries in my 2005 f-350 6.0 NOw it wont even crank, i dont have the keyless entry control. I heard there is a button in the steering column i can push to reset so that truck will start is this true
Old Apr 4, 2011 | 04:09 PM
bpounds's Avatar
bpounds
There is no such button.
Have you checked the voltage on the batteries? Does the radio turn on? Headlights? Do the injectors buzz? Vacuum pump run?
Why did you install new batteries? Was it hard to crank before?
Old Apr 4, 2011 | 06:19 PM
greentree ford
I got it started, replaced both batteries it has been slow cranking for about a week. I called on an old friend he talked me through it, problem was my factory installed alarm had to be reset with a push of the button. Located under the steering column by the fuses. Apperently you can also reset alarm with remote
Old Apr 4, 2011 | 06:25 PM
bpounds's Avatar
bpounds
You don't have a factory installed alarm, but you may have a dealer installed alarm.
Glad you got her started.
And welcome to FTE.
DragonMDB
Aug 10, 2014 01:33 PM
ethans91bronco
1978 - 1996 Big Bronco
Jan 16, 2011 08:48 AM
ironrick58
Nov 21, 2006 06:52 AM
Bsambear
Aug 5, 2003 03:13 AM
DrFord
Sep 14, 2001 06:57 PM
