Im thinking about buy an f-250 v10
I've been wanting to get an f-250 for a while. Ill be using it to trailor my track car. I found a 99 f250 ext cab with a triton v10 at a dealership here. 120,xxx miles. They're asking 9 grand for it. What is usually considered a good price for this truck? I posted a link to it below. One thing i was wondering about is its power. I have read (not sure if this is accurate) that the v10 should have 310 hp and 425 ft lbs of torque. My dad has an ext cab 99 f150 with the v8, and it feels faster than this v10. My guess is its due to different gearing. Is this correct? Or is there possibly something wrong with the truck?
Used 1999 Ford F-250 For Sale | Cedar Rapids IA
I should have posted resource. Thanks for the quick responses so far. Something i forgot to mention in the OP was i plan to pull a 2 or 3 car trailer on occasion with this as well. The cars are about 2800lbs each. Will the v10 be able to swing this?
Ford Modular engine - Wikipedia, the free encyclopedia
I'd be carefull about using wikipedia as a 'resource'. Here is something I just found here quick... 1999 Ford Super Duty F350 Review and Specs .: Articles
275HP
However I am sure it would handle pulling those cars just fine. Do you know what gears it has?
275HP
And what would u consider to be the maximum tow compacity of the f250 for a long haul? That article you linked me to said 11,000 but it was for the f350.
Redford, thanks for posting the axle info. I've wanted to find out what axle I have so I checked the door sticker and my axle was C3, and not being on the list I checked with the shop manual and found a different set of codes for the axle. I am really surprised that I have the 4.30 LS. No wonder I get around 10 mpg. Anyway, here is another set of explanations from the manual:
Axle Codes
The following lists the gear ratios on rear axles.
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
61 — 3.73 non-limited slip, F-350 (dual rear wheels)
F1 — 3.73 limited slip, F-350 (dual rear wheels)
62 — 4.10 non-limited slip, F-350 (dual rear wheels)
F2 — 4.10 limited slip, F-350 (dual rear wheels)
63 — 4.30 non-limited slip, F-350 (dual rear wheels)
F3 — 4.30 limited slip, F-350 (dual rear wheels)
66 — 4.56 non-limited slip, F-350 (dual rear wheels)
F6 — 4.56 limited slip, F-350 (dual rear wheels)
81 — 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
Axle Codes
I have no clue what gears it has. And im sure the dealership doesnt either. Is there an easy way to find out? A marking somewhere?
I dont tow much so I'm not a good one to ask. 8k is about as heavy as I have hauled, and half that weight was in the back of the truck. It did fine, but at 8k it is rather slow accelerating. Still did fine maintaining speed limit on the highway going up hills and all, but some of the steeper country roads require going down into 3rd.
The price would be good in my neck of the goods, great for a retail price.
But... I agree with dkf. Having driven both the non-PI and PI, the PI is much nicer for heavy towing.
And even with 3.73's, it should feel stronger than a '99 V8. This one may not be 100% up to snuff.
I'd suggest keep looking. More ideal for you would be a PI engine and 4.30 gears. Those make for awesome towing rigs.
Well I have a 2000 V-10 and I kick my self in the butt everyday for not buying a diesel. After reading all of this I'm guessing my truck is the non-PI and now I'm going to see what gears I have. Will it make a difference if I was to change the gears? I pull a 28ft boat and my truck is pretty sluggish pulling up hills and starting out from a dead stop. My friends diesel truck pulls it like it's not even back there. I say buy a diesel if you plan on towing. I went with the V-10 because I liked the looks of the truck better. Well if you really wanna buy a V-10 hit me up because I'll sell you mine so I can buy a diesel
